Proper Way To Protect Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 10:02 PM   #1
Rewards Points: 164
Proper way to protect wire
What is the proper way to protect nm cable coming down from the rafters to outlets mounted to my concrete walls in my basement shop?
ryan50hrl is offline   Reply With Quote
Old 08-19-2012, 10:10 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
EMT sleeved down the wall.
Old 08-19-2012, 10:12 PM   #3
Rewards Points: 164
I was under the understanding that nm couldn't run in the conduit
Old 08-19-2012, 10:23 PM   #4
k_buz's Avatar
Outdoors or underground it can't
Old 08-19-2012, 10:24 PM   #5
Rewards Points: 164
Are there limits how far it can run in the house, for example I can't run nm in conduit all the way across the basement ceiling right?
Old 08-19-2012, 10:27 PM   #6
Code05's Avatar
Rewards Points: 1,104
Can you retype this post a bit more clearly please.
Code05 is offline   Reply With Quote
Old 08-19-2012, 10:34 PM   #7
Rewards Points: 164
I'm not sure how to clarify it any further, can nm run in conduit? If so, any limits on distance? If no, why can it run down the wall in it?
Old 08-19-2012, 10:44 PM   #8
Code05's Avatar
Yes
[/quote] If so, any limits on distance?[/quote]
No
[/quote] If no, why can it run down the wall in it?[/quote]
NM in conduit is legal, just not outdoors or underground as K-buz said.
Old 08-20-2012, 07:03 AM   #9
Rewards Points: 2,516
I'd be more concerned as to why you have rafters in your basement.
The NM needs some type of physical protection when it drops vertically down an unfinished wall.
hammerlane is offline   Reply With Quote
Old 08-20-2012, 07:08 AM   #10
Rewards Points: 1,548
A variety of "conduit" including Wiremold (tm) is available for protecting wires and Romex type cable on walls where physical damage might occur.
Old 08-20-2012, 09:47 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
If your going to be running a lot of nm and want to put it in conduit....why not switch over to THHN/THWN stranded? It is a whole lot easier to pull through conduit than romex....and you can get more wires in it....
Old 08-20-2012, 10:00 AM   #12
Rewards Points: 164
I'm not running much, someone once told me you couldn't run Romex in conduit, so I was a bit perplexed. All of mines just run through the joists, however I knew I had to be protected somehow down the walls.
Old 08-20-2012, 12:09 PM   #13
Rewards Points: 164
How about Romex in my detached garage in conduit? That work?
Old 08-20-2012, 12:24 PM   #14
You must have an unlimited supply of Romex.
Old 08-20-2012, 12:27 PM   #15
JOATMON
ddawg16's Avatar
Wait until you try to pull 12/2 romex through a 1/2" EMT conduit........
The Following User Says Thank You to ddawg16 For This Useful Post:
brric (08-23-2012)
Proper conduit for running wire in garage? mrrr0809 Electrical 5 08-05-2012 04:55 PM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 01:05 AM
Question about proper way to wire this circuit shelzmike Electrical 7 04-12-2012 10:20 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
