Proper Way To Install TWO Breaker Boxes. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 08:30 PM   #1
proper way to install TWO breaker boxes.
WIthout going in to a lot of detail, I want to install a 2nd 40 amp rated box in my home. As I understand it, I can either request a meter base that has double cable capacity on the service side of the meter, or is it possible to "split" it using a buss bar system in a box. I have a feeling the answer will be "no" to the buss bar... or, better yet, does a box exist that has "pass through" capability for the service conductors? I'm an EE, NOT an electrician...
Cinci Joe is offline   Reply With Quote
Old 04-27-2011, 09:18 PM   #2
Licensed electrician
Rewards Points: 1,892
It would be very hard to fit a #8 AWG onto a lug in a meter base. The studs are about twice as big as the conductor.
You would also need to have the services grouped.
The splitter box you ask about is most likely a trough where conductors are run and could be tapped. Trough is typically just a long square box with a removable cover.
Wire Length AFCI breaker install issue 205bhamjim Electrical 5 02-24-2010 02:33 PM
Proper cable entry into breaker panel tns1 Electrical 12 08-26-2009 11:25 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
DIY Breaker Panel Install - Updated Photos jamiedolan Electrical 31 01-08-2009 01:39 AM
need proper breaker johndeere214 Electrical 4 06-04-2008 11:14 AM
