Proper Way To Install A LB - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 08:52 PM   #1
Proper way to install a LB
Hello. I'm getting ready to install my underground conduit hear soon and pretty much have everything I need to know for the most part except the proper way to install a LB. Im running a 1 1/2 pvc. so I went out and purchased my 4 1/2 hole saw to drill into my rim joist. Now to me in sounds almost to simple to install one. Drill hole.. push lb into hole... silicone outside. Is that is. I do plan after running wire to put some great foam from the inside of the house into the hole for fire protection and to keep the bugs out. Any other suggestions. I did buy some liquid nails and though I would put it on the outside of the conduit to bond the wood and pvc better.
Holt is offline   Reply With Quote
Old 11-05-2010, 09:06 PM   #2
Electrician
Rewards Points: 792
Is 4 1/2" a typo did you mean to say 1 1/2". If it is not a typo I have no idea what you trying to do.
You should drill a 1 1/2" hole in the joist put a piece of pipe through the joist and into the LB. Then another piece of 1 1/2" piece goes down from the LB and into the ground.
darren is offline   Reply With Quote
Old 11-05-2010, 09:21 PM   #3
ya the 4 1/2 was a typo I meant to type 2 1/2. I know its 1 1/2 pvc but its width is 2 1/2. I didn't think I needed a piece of conduit through the joist. Just a short piece with a bell end then I can just tack the wire down to main panel. It doesn't have to be conduit the whole way right since its pvc and not ridged metal, Right ? Thanks for the reply
Old 11-05-2010, 09:28 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what kind of wire are you running in this?
you need to secure the conduit near the LB so hold it in place.
Old 11-05-2010, 09:31 PM   #5
6/3 uf wire. I do already have some conduit clamps to hole the conduit after it exits the LB
Old 11-06-2010, 10:32 AM   #6
Rewards Points: 130
Your nuts if you think you can pull 6/3 UF through conduit for any distance. UF is direct burial cable and is not intended to be installed in conduit. It is not a code violation to do it, but it should be.
If you are just using conduit to get the cable underground, then you are doing it right.
Old 11-06-2010, 12:01 PM   #7
So should I return the wire and pick up the individual wires. What's it called thhn wire
Old 11-07-2010, 10:45 AM   #8
Rewards Points: 130
If you are running conduit all the way from one panel to the other YES. THHN/THWN. 4 individual conductors. H-H-N-G. The ground wire can be smaller that the three others. Whats the feeder size?
Or use the UF you already have. Just use the PVC conduit to protect the cable where it comes up out of the ground.
Most stores will not take back cut wire.
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
how difficult to install reverse osmosis filter grgryl Plumbing 3 02-07-2009 10:04 AM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
