Proper Splicing Thnn/thwn - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 05:40 AM   #1
Question
Proper splicing thnn/thwn
I'm running a 4 wire circuit to a new spa. The first 25 feet runs above ground in schd 80 pvc conduit from my 200 amp main to a junction box. At this point I plan on going underground in 1-1/2 pvc. How would I splice the #4str cu cable? Are split bolts OK? Compression splices? I have looked over quite a number of posts but have not found the information I need.
Recommendations are appreciated.
dpt1 is offline   Reply With Quote
Old 10-10-2007, 06:01 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
I use NSI Polaris Insul-Taps for anything over #8. WAY fast & easy and super clean.
http://www.dale-electric.com/detail?itemnumber=IT-4
Old 10-10-2007, 07:49 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Speedy showed these to me a few years back and they are the cats meow and worth the cost.
Only question I have is why are you splicing is it length of run and wire too short?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-10-2007, 01:23 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I just about used either split bolt or insluated taps but right now i am more on inslusated taps it work much faster than the split bolt methold useally about 1/4 of the time compared to old school methold [ split bolts] and much neater apparince as well
Merci, Marc
Old 10-10-2007, 05:45 PM   #5
Electrician philosopher
Polaris taps are the best for the DIYer... Very easy and self explanatory. Split bolts are just as effective and safe IF you know what kind of tape ( thick rubber splicing tape, and regular electrical tape) to buy and are careful making the splices.
Andy in ATL is offline   Reply With Quote
Old 10-11-2007, 05:04 PM   #6
Don't splice them.
A. Pull from the JB to the panel and from the JB to the spa.
B. If applicable, mount a GFCI disconnect instead of the JB and terminate them.
220/221 is offline   Reply With Quote
Old 10-12-2007, 10:51 AM   #7
Rewards Points: 204
This must be a monster of a spa. 1-1/2" conduit. What size conductors are you pulling?
Splicing cables sluggermike General DIY Discussions 6 09-23-2007 02:57 PM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 08:16 AM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 01:38 PM
