Proper Receptacle For Circuit? - Electrical - Page 6 - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 12:49 PM   #76
Originally Posted by Jim Port View Post
You do not need to wire using a switch loop.
So then both devices can share the neutral on 12/3 and I just run my hot through the desired switch?
Also, any answers to the previous question appreciated.
scottl31 is offline   Reply With Quote
Old 11-09-2013, 01:45 PM   #77
OK, I think I finally know what I'm going to do, but I have a question if anybody is still with me.
I was going to use this subpanel to feed these circuits:
http://www.homedepot.com/p/t/2022531...N#.Un6JRI3XW3C
But it was out of stock, so I found this one for a dollar more:
http://www.homedepot.com/p/Murray-12...e#.Un6OeI3XW3A
They appear to be the same, but they have a different model number and price.
Can anybody tell me the difference and if I should use one over the other?
Thanks,
Scott
Old 11-09-2013, 02:27 PM   #78
Licensed electrician
Rewards Points: 1,610
Look at the model number in the link provided. The guts are the same but the covers are for flush or surface mount. This is the last letter of the LCN004 part. S = Surface, F = Flush.
Old 11-09-2013, 02:48 PM   #79
It's confusing because the picture is the same for both, and on some web sites the LC004NFU is marked as surface mount.
So then the LC004NS is meant to be mounted ON the wall and the LC004NFU is meant to be mounted IN the wall? Correct?
Thanks!
Old 11-09-2013, 06:22 PM   #80
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Thanks,
Scott
outside dimentions are different ...LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Receptacle Question Pete77 Electrical 17 07-08-2013 07:44 PM
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 01:18 PM
Electrical power disappeared from switch to receptacle craighank Electrical 3 02-19-2012 01:06 PM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 07:51 PM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 06:29 PM
