#1 |
Electrical Contractor
Proper placement for breaker panel in laundry room
I am going to be replacing our breaker panel and putting it in the laundry room. Washer will be on one side and dryer on the other side with full access to the panel.
Main reason is because the old panel was not wired properly and I would like the breaker panel in a more acceptable location current panel is in the corner of a bedroom above some built in cabinets between a closet next to a window. Hard to explain but you just about have to sit on the cabinets in the corner to see the panel. Home was built this way. New location will allow me to just pull most of the wire back from the old panel to the new panel only leaving two circuits that I will have to run new wire to. And the rest are just in the laundry room. And it will allow my larger 250v loads to be very short runs. My question is what are the clearance and requirements that I will have to meet using this location. This room will also have a furnace and electric tankless water heater. Basically making this room my mechanical room. |
#2 |
Licensed electrician
You need a 30 inch width in which the panel does not need to be centered. You also need a 36" depth. The door needs to be able to open 90 degrees.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
retired elect/hvac/plumb
Where will the new panel be fed from?
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
#4 |
That should not be too hard to meet that requirement. I think the only thing I have to move is my washing machine water connections. They are right below where I want to put the panel.
#5 |
The new panel will be fed from my garage. Using 2-1/2" conduit and 4/0-4/0-2/0-#2 AL wire. Mobile home so service can't be connected to the home.
| The Following User Says Thank You to rrolleston For This Useful Post: | plummen (02-13-2012) |
#6 |
And how do you plan on splicing all those wires so they can be extended?
#7 |
Most like I said can be pulled and fed right into the new panel and if not long enough I will used junction boxes. But the circuits further away I will just run new wires to the first outlet or switch on the circuit. Everything in the laundry/utility room will just get all new wires and circuits since it's so close.
| Display Modes | |
| Mobile Home Electrical Panel Replacement | rrolleston | Electrical | 2 | 01-28-2012 06:27 PM |
| Installing an additional outlet in a laundry room | Condoowner | Electrical | 1 | 09-22-2011 10:50 AM |
| Placement of Electrical Panel | theatretch85 | Electrical | 4 | 01-05-2010 01:05 AM |
| No more room in panel. Sub panel? | sandyman720 | Electrical | 11 | 03-11-2007 09:15 AM |
| Replacing a laundry room roof. | Tomcat1066 | Building & Construction | 5 | 11-11-2006 04:08 PM |
