Old 02-09-2010, 11:03 PM   #1
Proper method for well pump wires coming through wall
In my 1940's basement I have a well line coming through the wall with the power for the well pump.
I am planning on relocating the well tank, so I will need to extend the wiring to the new well tank location.
The existing hole has 1" pvc water line and 2 10gauge wires (220v for the well pump)
Is there a proper method for this?
Otherwise I bought a gray PVC sealed electrical box. I was going to drill a hole in the back and the wires into splice it.
Then up through a new plastic pipe to the ceiling to run over to the new location.
I also need a standard method to attach this to my well switch - now it is just loose wires.
theedudenator is offline   Reply With Quote
Old 02-09-2010, 11:33 PM   #2
This is the type of box I bought.
Since I have to run 10gauge up and down the pipe, I bought 1" size.
Not sure if could go smaller or not.
Old 02-10-2010, 12:32 PM   #3
J. V.'s Avatar
I find these boxes to be the best for your application. You can get them in many varieties. As you can see it already has a threaded opening in the back for any cable or conduit connector. Just make sure you get a weatherproof cover with gasket (they come together).
Try to never use the top opening if you can help it. Heres a picture of the box.
I included a picture of a male conduit adapter. This will screw into the box and except a conduit. Included with the box are threaded blanks to fill any unused openings.
Old 02-11-2010, 12:10 AM   #4
I saw those also.
I think I will get that same box.
What is the problem with using the top opening?
Thats what I plan on doing.
Does it make sense to use 1" conduit for the 10gauge romex I need to run.
2 runs in a 1" pipe.
I think 3/4" would be too tight
proper method for paper faced drywall corners rocketdoctor Drywall & Plaster 2 12-06-2009 11:14 AM
well pump wires to pressure switch american501 Electrical 2 12-01-2009 09:13 PM
Primed Wall Has Screening Marks: Quick/Dirty Method to Smooth? Lovegasoline Painting 9 12-01-2009 06:19 PM
whats the proper method NHERal Roofing 3 11-03-2008 11:30 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 07:18 AM
