Old 09-08-2009, 12:44 AM   #1
Proper grounding of meter main to breaker panel
These diagrams are such a great resource. Now if only they were numbered...
If I understand the diagram below, no ground connection is shown between the meter enclosure and the breaker panel enclosure. Shouldn't it be a 4-wire connection with a bonded ground for the enclosures?
http://www.dropshots.com/stubbie4#al...09-22/19:47:22
tns1 is offline   Reply With Quote
Old 09-08-2009, 12:48 AM   #2
nap
You talking to me?
nap's Avatar
no. you bond at the first disconnect, which, unless the meter is a combo meter/disco is at the main disco in the panel.
the neutral is bonded in the meter base in residential meters so it is grounded via that connection.
Old 09-08-2009, 08:20 AM   #3
Licensed electrician
Not all power companies permit the grounding to take place in the meter socket.
Old 09-08-2009, 10:24 AM   #4
OK. I was comparing the diagram with the situation where the meter enclosure has a disconnect or main breaker built-in, thinking this would be the same as far as grounding. Now I see they are handled differently due to the location of the disconnect.
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 02:44 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 09:04 AM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 01:24 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
