Proper Grounding Of 220 And 110 Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 01:50 PM   #1
Proper grounding of 220 and 110 circuits
My landlord (of a barn I rent) added a 220 and 110 circuit for me. He routed conduit from the panel with both circuits to a j-box. In the box he added the 220 outlet of the type I requested. He also has a black and white wire (with wire nuts) in the box and tells me this is my 110 circuit.
I want to add a second 220 outlet and a new 4 gang 110 outlet and then route to some switched lights.
The 220 outlet has the two hots and a ground wire with no pigtail to the box.
1. To pull some armor cable for the 110 circuit from this box how to I get ground?
- To the box?
- To the ground of the 220?
- Should it go to both?
2. If I add a stub of conduit and a second box for an additional 220 outlet do I just run the wire from outlet to outlet with no ground to the box(es)?
bwx100 is offline   Reply With Quote
Old 09-15-2011, 01:54 PM   #2
Code05's Avatar
Rewards Points: 1,104
- To the box?
Landlord already failed. 2 supplies to a structure is generally illegal.
Wait, is the panel in the barn and is the conduit metal?
Code05 is offline   Reply With Quote
