Proper Ground With Plastic Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2005, 01:22 PM   #1
Proper ground with plastic boxes
Hello,
I'm in the process of doing a room in the basement, and just finished running the rough electrical. Since I'm using plastic boxes for my outlets, I want to make sure what I'm doing for ground meets NEC (since I don't have a copy of my own to reference).
Running 14-2 to all outlets.
Running a pig tail from the ground screw of each outlet to the ground wire of the 14-2.
Tie the ground wire into the grounding bar in the service panel.
Thanks in advance for the help.
Tim
tjandt is offline   Reply With Quote
Old 11-04-2005, 11:36 PM   #2
thats how I would do it and i'm a 5 yr apprentice but every day i'm amazed at how much I don't know. JB or speedy should be by to make sure we got this straight. HS
K2eoj is offline   Reply With Quote
Old 11-06-2005, 05:56 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Are you having this inspected? In my area all grounds in a box need a crimp sleeve to insure that the grounds will not come apart. They also make a green wire nut with a hole in it to allow a pigtasil to reach the outlet. What ever you do, make sure you have a good, tight connection!
jbfan is online now   Reply With Quote
Old 11-07-2005, 08:16 AM   #4
I won't be having it inspected, but want to make sure it's done right, nontheless.
Over the weekend, I opened up a couple of the outlets upstairs, and saw that they had used the wire nuts with a hole in the end to run the pig tail to the outlet. Since they just finished building the house in February, I'm going to assume that meets local code and do it the same way.
Thanks much for the replies! It's very helpful to have a place like this to bounce things off of more knowledgable people!
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
plastic or metal boxes for outlet wiring? yummy mummy Building & Construction 9 12-31-2006 01:37 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 05:54 PM
