Is This Proper? (Garage Switch) - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 02:34 PM   #1
Is this proper? (Garage switch)
I want to put 220 in my garage so I've been looking at what I have currently.
When I looked at it, it made me wonder if it was safe in it's current
In the garage now is a Crouse-Hinds GP321N.
It is rated for 30 amps. Is that 30 amps per pole or a total for both poles?
I ask because right now it has two 20 amp fuses. Is that proper?
This isn't mine, but it's the same model.
Thanks,
Mike
twinrider1 is offline   Reply With Quote
Old 03-17-2011, 03:11 PM   #2
Licensed Pro
That would be 30A per leg.
Old 03-17-2011, 05:57 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
30a@240v Total sorry there is no way to get sixty amps out of a 30a
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-17-2011, 07:47 PM   #4
joed's Avatar
Rewards Points: 11,994
Just because it is rated for 30 amps doesn't mean you can put 30 amp fuses in it. 30 amps is the max rating. If it is feeding #12 wire then 20 amps is the proper fuse.
Old 03-17-2011, 07:52 PM   #5
Maybe I'm mixing together two different questions. (Or I'm trying to combine the two answers. :-))
The box itself, let's say it's in a new installation. It's lists a max of 30amps. That's a max for the box, not each pole? So it could be 15 amps per pole.......two 15amp/120volt circuits (one per pole) or one 30amp/240volt (both poles running as one circuit).
Hope that helps instead of clustering it further.
(EDIT: Was typing as joed posted)
Old 03-17-2011, 08:39 PM   #6
I've been putting 30 amp fuses in 30 amp disconnects for 30 years.
R U saying that i've been doing this wrong, all my life?
Old 03-17-2011, 09:05 PM   #7
Scared Electrician
remember that OCPD is determined by wire size
Old 03-17-2011, 09:15 PM   #8
joed's Avatar
It depends on the wire attached to the fuses. I mention 20 amp because of this statement.
Old 03-17-2011, 09:32 PM   #9
The idea being the fuse is there to protect the wiring.
Backtracking a bit then, narrowing it down to the box itself. When it says 30amp max, does that mean it can handle 30 amps on each pole?
Old 03-17-2011, 10:54 PM   #10
joed's Avatar
Yes, 30 amps each pole.
Old 03-17-2011, 10:57 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
ok, a 30 amp rated disco means you can run up to 30 amps through it.
You cannot (legally) use a fuse over 30 amp size
You can put any size fuse smaller than that that will fit.
as another said; fuse size and conductor size are complementary to each other. You cannot use a fuse larger than the wire is rated for.
you do not add the 2 poles together to get the max available amperage. It 30 amps per pole. If you use it as a 240 volt circuit, you get 30 amps at 240 volts. If you use it to feed 120 volt circuits, you can get 2 30 amp 120 volt circuits out of it. You cannot get 1 60 amp 120 volt circuit from this.
Old 03-18-2011, 12:22 AM   #12
Ok, I get it now. In my head I kept thinking I had to divide the 30amps between the poles. I'm comfortable with DC systems, but I don't have much experience with AC circuits. It's a different way of thinking about things.
Ok, next step will be to see what size wire is running to the switch.
Old 03-18-2011, 08:31 AM   #13
joed's Avatar
The switch fuses protect the wire running FROM the switch, not TO the switch. The wire running TO the switch should be protected by a fuse or breaker in the panel supplying the power to this switch.
Old 03-18-2011, 10:32 AM   #14
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by twinrider1 View Post
...I'm comfortable with DC systems, but I don't have much experience with AC circuits. It's a different way of thinking about things...
Not really for the most part. I'm constantly converting an AC circuit to DC in my head...for installations, troubleshooting, etc. Power comes in, goes through devices, goes back out to source. Same as DC. Physical materials & hookup may be different, but it's the same principle (basically, with exceptions).
Kyle
Old 03-18-2011, 12:50 PM   #15
nap
You talking to me?
nap's Avatar
So, it is as one of my brother's teachers used to say:
It's the same only different.
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
Rewiring a garage Vertigo50 Electrical 6 11-17-2009 10:26 AM
Switch loop detached garage jamiedolan Electrical 2 02-10-2009 08:24 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 01:08 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
