Hey all! New to the forum. I'm in the process of finishing my basement and just had a simple (I hope) question for wiring. I am using two circuits with Romex 12/2 wire- one for outlets and the other for lighting. I brought through the garage wall and now I have to run them to the main panel. I was originally going to use 3/4" PVC conduit; however, I'm seeing some information state that a grounding wire must be used or if in a garage and the wire is less than 60" from the floor, steel conduit is necessary. Is all of this true? I already started using the PVC which is why I'm crossing my fingers that is acceptable. Thanks in advance for your input. I'm all ears!
So with that being said, I have no need to worry, right? I also failed to mention the wires are only 2 feet above the ground. Can I still use the PVC conduit in this circumstance?
The garage is attached. I do like the idea of a junction box although I think my lack of skill and knowledge may inhibit me from doing so. Thanks for all the input so far guys!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
