Proper Conduit Install - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 04:53 PM   #1
Proper conduit install
I have a 2 story home and I am wanting to run a feeder to my subpanel through the attic to the other side of the house. My question is this - Is there a limit on how high I can come out of the house? For example, if I want to exit the house at the top (even with the bottom of the roof), can I as long as I run the feeder in conduit? I am trying to avoid having to drop the line in the wall all the way down and then having to go through the brick.
Thanks for the help.
swami101 is offline   Reply With Quote
Old 07-11-2012, 05:13 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Sure... around my parts I would use SE type cable and not even use conduit... but this scares people from other parts of the country.
Old 07-11-2012, 07:23 PM   #3
Master Electrician
Rewards Points: 3,870
Of course you meant to say SER............
brric is offline   Reply With Quote
Old 07-11-2012, 07:35 PM   #4
E2 Electrician
Not at all, But yes, SER would be the type of SE type cable he would want to purchase if allowable in his area.
Old 07-11-2012, 08:29 PM   #5
liscenced electrician
Rewards Points: 538
I have no idea what youre suggesting but I'm guessing its really ghetto, although possibly not a code violation. Maybe a picture of what you are suggwsting
jimmy21 is offline   Reply With Quote
Old 07-11-2012, 09:59 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't have a picture handy, but IMO, it looks horrible. Others will argue that EMT looks horrible. Its all a matter of what you are used to seeing on a regular basis. Both are completely legal according to the NEC.
Old 07-12-2012, 01:29 AM   #7
Thanks for the responses. I just wanted to make sure I could drop it down from that height. I will be using pvc conduit for it and into the ground from the subpanel for my hot tub. It makes it much easier than having to fish down a wall, then drill through brick. The second story of the house is siding. Its also in the backyard, so it will not look as bad. Any other ideas for this woudl be greatly appreciated.
Old 07-12-2012, 02:53 AM   #8
S.e.
Does "S.E." stand for "Scorched Earth"...?
kontoose is offline   Reply With Quote
Old 07-12-2012, 02:56 AM   #9
..."S.E." Does that, by the way, stand for "Scorched Earth...?
Old 07-12-2012, 02:58 AM   #10
Heehee...: Ghetto...?
Old 07-12-2012, 03:03 AM   #11
No problem... I get your concern: In high-rise buildings there are codes that limit the height of a vertical drop of conductors in conduit -- stops or chocks need to be installed to deal with the accumulated weight of the drop. You have nothing to worry about with a 2 story building. Just make sure your grounds are good...
The Following User Says Thank You to kontoose For This Useful Post:
swami101 (07-12-2012)
Old 07-12-2012, 05:11 AM   #12
E2 Electrician
That changes my selection choice, you need an insulated grounding conductor to the hot tub...
Old 07-12-2012, 06:11 AM   #13
k_buz's Avatar
I thought you said this was hitting a sub panel?
Old 07-12-2012, 05:18 PM   #14
E2 Electrician
One end of it was.
Old 07-12-2012, 05:53 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
If he is hitting a sub before he gos to the hot tub, then he dosen't need the insulated ground.
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Would like advice on whether this violates NEC; flex conduit through (kitch) cabinet. buckybadger Electrical 2 12-15-2011 10:23 AM
Running electricity on a pergola to install fan Vance Electrical 0 10-23-2011 11:43 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
