Proper Calculation For Circuit Size - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 05:11 PM   #16
Originally Posted by plummen View Post
You dont think there would be more resistance /heat built up in that wire over 80' than there would be in a piece of 6/3 going the same distance with the same load on it?
Either way I guess its not a big deal,we're just beating another dead horse here
Heavier wire for same current = less wire temp. rise above ambient = longer wire insulation life.
The Following 2 Users Say Thank You to Yoyizit For This Useful Post:
frenchelectrican (02-15-2012), plummen (02-14-2012)
Old 02-14-2012, 07:32 PM   #17
Rewards Points: 152
I dont know if i would consider that a continuous load or a cry for help myself
Have you had them serviced lately to figure out why theyre running so much?
Maybe its time for a replacement/upsizing
Last summer we had over 100 days over 100 degrees. We were all crying for help. Rolling blackouts were somewhat common last summer. It is not unusual to see AC units running 4-6 hours non stop during the day. I don't know if the local electricians figure continuous or non continuous I've never asked. Practicality would say continuous load in such a harsh environment.
Again, I apologize for hijacking the "oven" thread.
David
n175h is offline   Reply With Quote
Old 02-15-2012, 01:03 AM   #18
" Euro " electrician
frenchelectrican's Avatar
About time you did something right.
Merci.
Marc
Old 02-15-2012, 01:39 AM   #19
Julius793's Avatar
David
Ac units are considered continuous loads (440.32) however they have different sizing of conductors which you can try to understand by reading 240.4 (g).
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-16-2012, 09:15 AM   #20
Merci.
Marc
Vous me louez trop!
Tags
breaker , oven , wire sizing
What is the proper way to cut CBU around windows avtck Remodeling 2 05-22-2011 06:27 AM
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
Proper awg wire size to use? Suzuki91vx800 Electrical 36 06-23-2009 04:18 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 04:42 PM
