Proper Awg Wire Size To Use? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 02:06 PM   #31
Originally Posted by money-pit View Post
You can try snaking it first or use an existing conductor as a pull rope
Also which ever connector your pulling out of .I would thread on a metal bushing to protect the pvc connector
Metal elbows buried underground are required by the utilities in most places now
Good Luck
Metal elbows on PVC?
Never heard of that, not required around here
As I remember only (4) 90 turns are allowed between pull points
You use an exisiting conductor by attaching the new wire & another snake/rope to pull the exisiting conductor BACK thru the conduit. I'm not sure that will work with #4 & the size conduit you have
Protect the PVC connector?
We cut & glue PVC, nothing threaded to protect
Where the PVC goes into the panel a bushing is required - I use the plastic ones
Old 06-23-2009, 02:35 PM   #32
No
You use and existing conductor as the pull rope
You just tie on a the ground conductor (1-#10 &1-#4)and replace the conductor you are pulling out
He said he pulled in Thhn Thwn so I would see if you could get one of them to move first.If not, snake it an just pull the ground but watch the live bus in your main panel if using a metal snake
Sometimes you just can't pull straight out the panel with the guts in there.
Thats why I'll use a metal bushing till the wires in and then repace with a plastic
Plastic bushings/connectors and elbows for that matter can create alot of friction and will melt
Use lots of soap
money-pit is offline   Reply With Quote
Old 06-23-2009, 02:45 PM   #33
Rewards Points: 2,350
Electricians that do alot of underground work do this pretty often. On long pulls, a rope or the wire can burn through a PVC ell, so we use rigid 90s. The code addresses specifically, and allows us to get away with not bonding these if they are 18" deep or greater. Don't know the article right of hand though.
Old 06-23-2009, 02:46 PM   #34
So you want him to go out & buy another piece of #4 to use as a pull wire?
And buy a metal bushing then throw it away after?
I used the plastic on a 100' pull, no problems, no need to spend more $$
I did buy the yellow pull lubricant - well worth the $$
I'd be careful on using any soap unles you know it doesn't have any animal fat in it
Thanks for the info InPhase
But you do it because it is better, or required?
Old 06-23-2009, 02:54 PM   #35
I do it because once you burn through the ell, it is nearly impossible to complete the job. If you have a long run before the 90, then a good distance to go after that, it is a good idea to use a rigid ell.
Old 06-23-2009, 03:06 PM   #36
Just trying to give'em some safer options
Better to spend a little extra cash and be safe
You could for that matter just pull everything out
with a drag line attached
You never know Be careful with that metal snake.....hmm
Old 06-23-2009, 04:18 PM   #37
Yes, but there is a big difference between "required"
and
It's better if you have a long pull
I do like to hear/learn of better ways to do things
So Thanks for bringing it up !
Wire size for 100 amp basement sub-panel jbrown77 Electrical 4 10-25-2009 09:58 AM
Please confirm wire size and type for amperage. wantsomegetsome Electrical 14 05-07-2009 05:49 AM
Subpanel wire size surrogate Electrical 15 02-14-2009 08:47 PM
Anyone know proper size for room a/c-heat? Duane 70 HVAC 7 10-04-2008 10:17 AM
Wire size for distance Question fburke Electrical 4 07-28-2007 09:29 AM
