Project: Running Electricity Into A Safe - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 07:45 PM   #1
Project: Running electricity into a safe
Great forum! First time poster here.
I've been searching far and wide for a multi outlet or power strip with a detachable cord. The purpose of the detachable cord is so that the the multi outlet or power strip can be placed inside the safe and the cord could be run through a small hole and out to the AC outlet.
(ETA: The purpose of having electricity in the safe is to provide interior lighting and a de-humidifier, possibly another small electrical appliance)
Having no luck finding something like this, I'm starting to realize that this might be better done as a 'DIY' project. That being said, I'm looking for some ideas and/or answers to some questions:
Should I just use your basic everyday power strip, cut it, run the wire through, and then just reconnect the wires?
or
Should I build an outlet box from scratch and if so, what exact parts/materials should I use? I'm a total newbie to this kind of stuff so I'd need to know very specifically what I need as I have no idea what a lot of stuff is called.
I'm leaning toward my first option (everyday power strip) being that it just seems so simple. I'd be curious to hear anyone's opinion on these ideas.
Thanks!
niceguymr is offline   Reply With Quote
Old 05-20-2009, 09:19 PM   #2
DIY
Rewards Points: 150
How big is the safe?
And what's the combination? It's important :D
gp_wa is offline   Reply With Quote
Old 05-20-2009, 09:24 PM   #3
Iny money in thar? Thas silly, you mus want the lite, so's to count the money!
Old 05-20-2009, 09:59 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
not allowable per code.
why don't you just run power in to the safe just as if it were a room? You know, recep on the wall. Conduit for exposed wire. A switch for the light.
outlet for a security camera so when gp-wa comes over to see the safe (when you aren't there, of course)
The Following User Says Thank You to nap For This Useful Post:
Ravenworks (04-08-2012)
Old 05-20-2009, 10:42 PM   #5
Thinking about doing that. Running power into the safe and having a 2 outlet 'box' to plug stuff into.
Speaking of light switches, I want to have the lights come on automatically when the door is opened, but not with a motion sensor, but a physical switch that is activated when the door opens. Any ideas on where I can find something like this?
Old 05-21-2009, 12:18 AM   #6
nap
You talking to me?
nap's Avatar
sure.
something like this, which would be set into the door jamb and hidden
http://www.residential-landscape-lig...LLD1885EDW.htm
or there are switches like this that are surface mounted:
http://www.diytrade.com/china/4/prod...c_contact.html
that last one is not 120 volt rated but I could not find what I was looking for but it is a similar style of switch.
Old 05-21-2009, 12:35 AM   #7
DIY
Rewards Points: 150
Thanks for the tip sucker, I'll wear a hockey mask, they'll never know it was me
Old 05-21-2009, 08:14 AM   #8
Rewards Points: 16
Sorry, meant to post to different question!
ponch37300 is offline   Reply With Quote
Old 05-21-2009, 04:19 PM   #9
UPDATE:
I decided to step up the idea a bit and instead of having a multi strip outlet just sitting in the safe, I thought it would look more 'professional' to actually have a wall outlet installed. So I picked up the following items:
14 gauge medium duty power cord, 9 ft long, with a plug already on one end and pre stripped (bare) on the other + 'On Wall' metal outlet box/kit
Here's the outlet kit out of the package (screws not pictured). This seems like it will come out very nicely when it's all done.
The funny thing is I don't even have my safe yet. It will be delivered next week, afterwhich, I will post pictures of this little project as I do it.
ETA: Can anyone tell me if there is any risk of electrical shock with the ground wire being bonnected to the box which will be screwed into the interior steel panel of the safe?
Old 05-21-2009, 04:53 PM   #10
nap
You talking to me?
nap's Avatar
actually, the ground wire connected to all metallic items is what makes them safe. The equipment ground conductor (EGC) is a unbroken path back to the panel and its purpose is to facilitate the breaker to trip if or when there is a short circuit.
Old 05-21-2009, 06:33 PM   #11
I guess I'm going to need some sort of clamp around the wire that will keep it from being able to be pulled out of the outlet box. Maybe another clamp on the other side of the box too just to hold it in place extra well. Any electrical people here know what that's called so I know what to ask for?
Old 05-29-2009, 05:31 PM   #12
Update
And here's the electrical work.
The extra slack that you see there just needs to be pulled out of the back of the safe.
I haven't gotten the lights yet but when I do, I will update.
Old 05-29-2009, 05:34 PM   #13
I was thinking a walk-in safe when you said dehumidifier
Old 05-29-2009, 06:30 PM   #14
DIYer
Yeah this looks like a portable* safe, in which case building codes wouldn't apply, just common sense and good engineering practices.
*or at least, movable.
Gigs is offline   Reply With Quote
Old 05-29-2009, 10:38 PM   #15
5' x 3' x 3'
1000 lbs and movable with the right equipment
Not really a 'walk in' safe, but you could certainly walk into it if you hunch over a little
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Running electricity to fireplace. Clutchcargo Electrical 6 12-01-2007 10:47 PM
help running electricity to barn kavik001 Electrical 10 09-10-2007 05:45 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
