hi,
I have searched the forum and did not find a recent post similar to mine.
I am looking into installing a Programmable Timer Switch – Honeywell RPLS740B.
The primary function I would like to achieve is to turn the outdoor lights on and off without having to be home to do so.
http://yourhome.honeywell.com/home/...rity/Programmable+Timer+Switches/RPLS740A.htm
http://www.amazon.com/Honeywell-Eco...8&qid=1352472670&sr=1-1&keywords=timer+switch
Mainly picked this one... cause of its high good reviews.
This switch will control 2 CFL light fixture to the left/right of the garage and also controls a front porch light.
Any advice to do and dont's? I am aware of the normal ones... make sure power is turned off from the breaker, etc.
This home is a new construction home within city limits... so a neutral wire shouldn't be a problem.
I will check the wattage of the fixture and post an update. Anything else I need to check?
If anyone has an alternative timer switch to use... I would consider it.
Please advise.
Please advise.
