Programmable Timer on 3-way
2K views 1 reply 2 participants last post by  zpm
Hi all
I'd like to install a programmable timer to turn my outside lights on and off. I've been looking at the Honeywell TI032 model.
The problem is, I need to install it where there is currently a 3 way switch. Currently coming into the switch there is a red wire, black wire, another black wire to common screw on switch, and a ground wire. There are a couple white wires in the box (not attached to the switch) wire nutted together. I assume these are the neutral.
I'm not sure if this model timer will work for me. Can anyone provide some insight? If this one won't work, are there others you'd recommend?
Thanks!
Dave
