Programmable Electronic Timer Switch To Electronic Door Lock? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 07:07 PM   #16
Rewards Points: 3,256
Close, but you have the terminals backwards. The solenoid wire would go to 1 and 2. Where are you getting 9 volts from?
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
freedom1st1776 (03-09-2012)
Old 03-09-2012, 07:10 PM   #17
You would have to see how much current the timer takes to run and then figure battery time. Joed has a good idea if you can use a small plug-in DC transformer to power the timer. I also see that the timer can be powered from 120 volts AC so that may be another option.
Old 03-09-2012, 07:24 PM   #18
Sorry, meant to say that. Thought I numbered them differently.
I was just going to have an external 9v battery connector. I also saw some 2 x AA, 4 x AA, 6 x AA, and 8 x AA battery packs that would work. Would either of these setups last longer than just 1 9v...or 2 9v?
Thanks for all the help.
freedom1st1776 is offline   Reply With Quote
Old 03-09-2012, 10:53 PM   #19
12v timer vs 24v timer
Would there be an advantage to getting a 24v programmable timer rather than a 12v model?
Old 03-10-2012, 09:39 AM   #20
joed's Avatar
Rewards Points: 12,920
Since the lock operates on 6 volts(4 AA batteries) there would be an advantage of getting a 6 volt timer. Then you could operate both them off the same supply. I would get a plug in 6 volt power pack and run them both.
Tags
electronic lock , programmable timer , switch , timer
Help with timer switch aftermath Electrical 2 11-23-2011 12:59 PM
Timer switch at end of run tmaher Electrical 3 05-16-2011 06:06 AM
Trying to install wall timer in place of switch bigcutts Electrical 3 02-02-2011 03:41 AM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 11:02 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
