Problems Wiring Up Food Disposer To Switch - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 01:29 PM   #31
Jim Port please tell me where the direct to short/neutral is at on the switch? because I dont see it is it because I have the white on the switch or what?
Because I thought you would need to have 2 blacks on the switch to close the circuit.
Originally Posted by Jim Port View Post
You have done all this work in your house and still do not recognize a direct short to neutral at the switch?
treich is offline   Reply With Quote
Old 03-31-2013, 01:37 PM   #32
" Euro " electrician
frenchelectrican's Avatar
I did see a excat a perfect probem right there.,
So I will give you a answer to fix this mess.,
First of all dump that three way switch and get a single pole switch .,
Next at the switch box location cap off the white wire that is netural right there and leave it alone unless you get one switch with polit light.
Hook the black et red wires at the single pole switch and done with that part.
Now at the receptale location wirenut two black conductors and leave that part alone now the white conductors you will have to make a pigtail wirenut that and run a white pigtail to silver screw .,, that done with that part.
Now the red wire from the switch goes to the brass colour screw and that it ya done right there.
That should work properly without kicking the breaker out ( I think it is the time to get new breaker anyway due you allready have couple hard short circuits so pony it up for new one. )
Oh by the way before you do any more projects make sure you get Electrical simpifed book or get someone whom know what they are doing.
Merci,
Marc
Last edited by frenchelectrican; 03-31-2013 at 07:01 PM. Reason: changed one part to bold to make sure someone understand this clear
The Following User Says Thank You to frenchelectrican For This Useful Post:
treich (03-31-2013)
Old 03-31-2013, 02:01 PM   #33
frenchelectrican that worked out great and now its working THANK YOU SO MUCH!!!
Merci,
Marc
Old 03-31-2013, 02:13 PM   #34
glad it worked out for you
jratftcc is offline   Reply With Quote
Old 03-31-2013, 02:26 PM   #35
Rewards Points: 512
treich,
Glad it's working.
you have to get a 15 amp breaker for this install, no matter what it costs, because the 14 AWG wire is designed for 15 amps only.
Old 03-31-2013, 06:50 PM   #36
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by sirsparksalot View Post
treich,
Glad it's working.
If you weren't half way across the country I'd bet you a steak dinner that this will NEVER get changed.
All this guy cares about is "does it work".
Old 03-31-2013, 07:00 PM   #37
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
I just love these threads. Like another poster said make some popcorn and sit back and enjoy.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
electures (03-31-2013)
Old 03-31-2013, 07:03 PM   #38
Yeah but just wait until someone get too stubborn to admit it. the last time I have to deal one stubborn dolt I just simply reply in full French ( of course I do speak in french I grew up with it )
Just ask couple guys in here what I will do with them and enjoy the popcorn.
Merci,
Marc
Old 03-31-2013, 07:15 PM   #39
Ok I am taking up donations to buy me the 15a breaker for this setup LOL.. so you guys can get off my case about it.
Old 03-31-2013, 10:28 PM   #40
Rewards Points: 512
Well, I do like longshots
Wiring Switch For New Chandelier Haselsmasher Electrical 1 12-31-2012 12:57 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
