Problems Wiring Up Food Disposer To Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 01:20 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by treich View Post
well this an older breaker so finding an 15A is going to alot harder to find so I am just using whats in the breaker which is 20A.
OK, so then I'll ask why did you run #14??
Just because that is the breaker you have is absolutely NO reason for an incorrect and non-complaint install.
At this point you rant the wire, get the right breaker. Period.
Old 03-31-2013, 01:27 PM   #17
Speedy I would have to order an breaker for it and them breakers are 60 dollars an piece... reason why I am running #14 wire is because that is only thing I have...
treich is offline   Reply With Quote
Old 03-31-2013, 01:28 PM   #18
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
ok i'll bite ... what brand of breaker is it ...
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Speedy Petey (03-31-2013)
Old 03-31-2013, 01:31 PM   #19
Sorry, but that is NOT an acceptable answer. You then should have just gotten the right wire.
WHAT is with people cheaping out on electrical installations. Isn't DIYing it saving you "tons" of money???
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (03-31-2013)
Old 03-31-2013, 01:32 PM   #20
You had plenty of money to buy the disposal though, didn't you?
Old 03-31-2013, 01:45 PM   #21
Speedy Petey disposal was only 70 dollars and what kind of breaker box this is The wadsworths electric mfg co which they do not make brakers anymore for this panel and yes I checked at menards and they can get them for 60 dollars and they would have to order it.
Old 03-31-2013, 01:53 PM   #22
here is 2 photos how Philly told me but I still dont see where 2 extra black wires come into play if there is already 2 black wires used up.
Sorry if the photos are not clear I used my ipod to take them.
Problems wiring up food disposer to switch-wiringatswitch.jpg   Problems wiring up food disposer to switch-wiringunder.jpg
Old 03-31-2013, 02:04 PM   #23
Electrical Enthusiast
Rewards Points: 504
Have you tried looking on eBay for the breaker you need? Using #14 on a 20 amp circuit would be a code violation, and could be dangerous if you ever were to overload it.
Kyle_in_rure is offline   Reply With Quote
Old 03-31-2013, 02:06 PM   #24
Kyle yes I did and no luck...
Old 03-31-2013, 02:07 PM   #25
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm waiting for the OP to state he didn't hire an electrician because they are too expensive.
OP...you should not be doing electrical work. You have no clue what you are doing. You obviously didn't do any research what-so-ever before you started.
Looking at your pictures, I have no idea what you have going on, but I'm guessing that your problem is on that 3 way switch. Looks like a direct short to me.
The Following User Says Thank You to k_buz For This Useful Post:
Old 03-31-2013, 02:08 PM   #26
Oso954's Avatar
Rewards Points: 446
1) turn the breaker off.
2) save some money.
3) call an Electrician.
You are in so far over your head that you are a danger to yourself and others.
(And no, you don't have it wire as Philly said.)
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 03-31-2013, 02:09 PM   #27
Its not time to bust my chops over on this and I have rewired my down stairs basement outlets so dont be saying I shouldnt be doing this... I just came on here looking for some help and not here to bust my chops over 14/3 wiring...
Old 03-31-2013, 02:10 PM   #28
k_buz's Avatar
Suit yourself...
Old 03-31-2013, 02:11 PM   #29
Ok your going to bust my chops 2 wow.... Ok I just asked for some help..
2) save some money.
Old 03-31-2013, 02:22 PM   #30
Licensed electrician
Rewards Points: 1,054
You have done all this work in your house and still do not recognize a direct short to neutral at the switch?
Wiring Switch For New Chandelier Haselsmasher Electrical 1 12-31-2012 01:57 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
