Problems Wiring Up Food Disposer To Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 11:56 AM   #1
Problems wiring up food disposer to switch
Hi Guys
I just bought and food disposer and when I try to wire up to an switch when I turn it on it blows the breaker all the time. How I got the wiring setup is coming from power source its on 14/2 wire then at the disposer its at 14/2 wire also but at the switch its 14/3 wire and only wires I see on the disposer is white n black. I figured of course you wire black to black and white to white well it dont work that way. So what am I doing wrong here on the wiring?
treich is offline   Reply With Quote
Old 03-31-2013, 11:58 AM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by treich View Post
Hi Guys
what did the switch do before you added the garbage disposer ???
Philly Master is offline   Reply With Quote
Old 03-31-2013, 12:00 PM   #3
well this is an new install I forgot to say that So I installed the new switch and new wiring.
Old 03-31-2013, 12:14 PM   #4
funfool's Avatar
Rewards Points: 534
All you need is to tie the white neutrals together, same with ground, and the black's go to the switch. If this is blowing breakers then is another problem.
A typical garbage disposal setup would be to install a outlet inside the cabinet, run one side of the outlet hot all the time, while the other side is ran off the switch.
Just use a cord to plug in the disposal to the switched outlet, and have the unswitched outlet for the dishwasher to plug into.
funfool is offline   Reply With Quote
Old 03-31-2013, 12:15 PM   #5
Rewards Points: 516
Hi Guys
where are you getting power from the operate the switch/disposal ?
Old 03-31-2013, 12:26 PM   #6
Philly its coming directly from 20amp breaker.
Old 03-31-2013, 12:47 PM   #7
Rewards Points: 516
feed wire (power from breaker ) to the switch first ....
whites wire nutted together, nutted together grounds, and switch connected to ground with green screw ....
1 black each to each switch screws
(**then if you really want to do this correctly ...**)
wired to an outlet ... under the sink ..
buy a 18" appliance cord or less ( three prong ) install it on the disposal then plug the disposal into the outlet ...
Old 03-31-2013, 12:47 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hi Guys
Why do you have 14/3 wire at the switch?
I'm also confused as to exactly what you did. So this is how I'm understanding your description
You have 14/2 from breaker to the disposal .. then you ran 14/3 to the switch from the disposal ??
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Philly Master (03-31-2013)
Old 03-31-2013, 12:55 PM   #9
Stubbie the reason why I had an 14/3 at the switch I was installing an 3way switch bc I figured use the red wire to connect the black wire to the disposer but that still throws the breaker.
But I guess I am going have to do the outlet to switch setup since my way isnt going to work.
Old 03-31-2013, 12:58 PM   #10
Rewards Points: 516
just forget about the red wire as it is not needed in this application ...
the using the outlet is the safer way .....does not really change the wiring i said ...
Old 03-31-2013, 01:01 PM   #11
So how would I wire up the switch to outlet setup? so the switch can turn off n on the disposer at the outlet?
Old 03-31-2013, 01:05 PM   #12
Rewards Points: 516
feed wire (power from breaker ) to the switch BOX first .... that give you 2 whites and 2 blacks and 2 grounds
then you will have 2 black wire left
1 black wire to each to switch screws
correct ... @ the OUTLET >>>black to the gold screw white to the silver screw .. ground to the green screen ....
Old 03-31-2013, 01:05 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
And change the 20A breaker to a 15A. WHO told you to run a 20A with #14??
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 03-31-2013, 01:09 PM   #14
Rewards Points: 516
LOL nice catch ......
Old 03-31-2013, 01:11 PM   #15
well this an older breaker so finding an 15A is going to alot harder to find so I am just using whats in the breaker which is 20A.
Wiring Switch For New Chandelier Haselsmasher Electrical 1 12-31-2012 01:57 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
