-   -   Problems wiring up food disposer to switch (http://www.diychatroom.com/f18/problems-wiring-up-food-disposer-switch-175950/)
treich 03-31-2013 10:56 AM
Hi Guys
I just bought and food disposer and when I try to wire up to an switch when I turn it on it blows the breaker all the time. How I got the wiring setup is coming from power source its on 14/2 wire then at the disposer its at 14/2 wire also but at the switch its 14/3 wire and only wires I see on the disposer is white n black. I figured of course you wire black to black and white to white well it dont work that way. So what am I doing wrong here on the wiring?
Philly Master 03-31-2013 10:58 AM
Originally Posted by treich (Post 1149574)
Hi Guys
what did the switch do before you added the garbage disposer ???
treich 03-31-2013 11:00 AM
well this is an new install I forgot to say that So I installed the new switch and new wiring.
funfool 03-31-2013 11:14 AM
All you need is to tie the white neutrals together, same with ground, and the black's go to the switch. If this is blowing breakers then is another problem.
A typical garbage disposal setup would be to install a outlet inside the cabinet, run one side of the outlet hot all the time, while the other side is ran off the switch.
Just use a cord to plug in the disposal to the switched outlet, and have the unswitched outlet for the dishwasher to plug into.
Philly Master 03-31-2013 11:15 AM
Hi Guys
where are you getting power from the operate the switch/disposal ?
treich 03-31-2013 11:26 AM
Philly its coming directly from 20amp breaker.
Philly Master 03-31-2013 11:47 AM
feed wire (power from breaker ) to the switch first ....
whites wire nutted together, nutted together grounds, and switch connected to ground with green screw ....
1 black each to each switch screws
(**then if you really want to do this correctly ...**)
wired to an outlet ... under the sink ..
buy a 18" appliance cord or less ( three prong ) install it on the disposal then plug the disposal into the outlet ...
Stubbie 03-31-2013 11:47 AM
Hi Guys
Why do you have 14/3 wire at the switch?
I'm also confused as to exactly what you did. So this is how I'm understanding your description
You have 14/2 from breaker to the disposal .. then you ran 14/3 to the switch from the disposal ??
treich 03-31-2013 11:55 AM
Stubbie the reason why I had an 14/3 at the switch I was installing an 3way switch bc I figured use the red wire to connect the black wire to the disposer but that still throws the breaker.
But I guess I am going have to do the outlet to switch setup since my way isnt going to work.
Philly Master 03-31-2013 11:58 AM
just forget about the red wire as it is not needed in this application ...
the using the outlet is the safer way .....does not really change the wiring i said ...
treich 03-31-2013 12:01 PM
So how would I wire up the switch to outlet setup? so the switch can turn off n on the disposer at the outlet?
Philly Master 03-31-2013 12:05 PM
feed wire (power from breaker ) to the switch BOX first .... that give you 2 whites and 2 blacks and 2 grounds
then you will have 2 black wire left
1 black wire to each to switch screws
correct ... @ the OUTLET >>>black to the gold screw white to the silver screw .. ground to the green screen ....
Speedy Petey 03-31-2013 12:05 PM
And change the 20A breaker to a 15A. WHO told you to run a 20A with #14??
Philly Master 03-31-2013 12:09 PM
LOL nice catch ......:whistling2:
treich 03-31-2013 12:11 PM
well this an older breaker so finding an 15A is going to alot harder to find so I am just using whats in the breaker which is 20A.
