Problems With Square D Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 07:19 PM   #16
I must have been tired......yeah - needs to be cleaned up some
Too much sheathed cable in the box, paper needs to be removed
Not as bad as some I have seen posted on here
Old 12-04-2009, 08:44 PM   #17
Yeah, I agree it's a mess, but I've got plans to tidy it up a bit in a couple weeks. I eliminated the 2 tandems, which were never really necessary, and two of the cables running into the box will disappear. I had 20A service running to each sump pump (3 total), which was not necessary, so I consolidated two sump pumps on one breaker and the other one on the other. One of the reasons why I left the sheathing on the cables was because I didn't like the idea of running ground wires real close to the exposed top hot bus bar, but in cases where I feel uncomfortable leaving them exposed, I'll connect the grounds to insulated wires and run that to the ground bar and eliminate the excess sheathing. Remember, I installed this box 2 years ago when I was still exceptionally nervous about dealing with electricity. Since then, I've learned a lot, and believe me, this messy subpanel is still 10x better than the electrical service we used to have (fuses, cloth wiring, sparking outlets, etc...).
bltglt507 is offline   Reply With Quote
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
Shock problems, from subpanel WesternNY Electrical 17 06-15-2009 01:53 PM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 09:29 PM
