Problems With Running Wires Through Dry Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 01:55 AM   #1
Problems with running wires through dry wall
I am trying to wall mount a TV. In order to run wires inside my dry wall, I bought this product http://www.legrand.us/wiremold/at-ho...x#.UMrYYm8vaSo. Unfortunately I didn't foresee two problems:
1. My dry wall has insulation inside. Would it be safe to run a electrical cable inside dry wall which contains insulation. Can a spark burn the insulation?
2. If you look at this video demonstrating how to use the product http://www.youtube.com/watch?feature...v=ly4yIW1gfts#! the upper mount of the assembly has a depressed single plug point into which the TV plug is supposed to go. Unfortunately I ordered a roku which I want to mount behind the TV and that means I need two plug points instead of one. Are there any socket extensions that would fit in the depressed mould provide more than one outlet?
salilsurendran is offline   Reply With Quote
Old 12-14-2012, 06:16 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
They make other brands that have 2 receptacles.
Romex is made to run inside the walls and to touch insulation.
Old 12-14-2012, 06:26 AM   #3
Rewards Points: 1,536
Sparks do not happen in the middle of a continuous undamaged run of wire or cable.
It is important that any joints or splices be inside junction boxes with accessible covers for for a variety of reasons including the possibility of a spark occurring if a connection should become loose.
Now I question the unreliability and spark hazard of knob and tube wiring with soldered joints where the conductors are spaced and have enough tension to not actually pass within an inch of each other.
Old 12-14-2012, 09:28 AM   #4
Rewards Points: 13,994
I just cut ut the sheetrock so I have complete access to mount the outlet, and cut out a recessed area in the studs to mount a 2 X 6 or 8 so the lags to hold up the TV mount have a solid place to screw into.
Running wires alongside or through ductwork j_sun Electrical 1 07-13-2011 11:11 AM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 08:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
