Problems With Radiant Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 10:20 PM   #1
Problems with radiant heat
Wondering if someone here can help.
Our house is set up on off peak electric ceiling heat with GFA backup. Yesterday, our bedroom heat "stuck" on and ran the temp up to 80+. I pulled the thermostat and found a mess in the box, and some of the wires had insulation melted off. I believe hot was shorted to the thermostat line - bypassing the thermostat. Not positive, though - when I pulled the thermostat out it destoryed any hard evidence.
So, today I trimmed the bad wire back and replaced the thermostat for good measure. It doesn't seem to be working now, I'm concerned something else may be wrong.
Wondering if anyone has seen the insulation melted off wires and how much heat do you need to get to that point???
cebeling is offline   Reply With Quote
Old 03-10-2008, 09:06 PM   #2
Union Electrician
goose134's Avatar
There may be something wrong with your power supply, or the low voltage source. If there is, it should be at the unit itself, though I suppose a short of some kind could have occurred in the T-stat. I would post this question in HVAC, you may have some luck there.
goose134 is offline   Reply With Quote
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 08:58 AM
radiant heat in floors What have I done HVAC 2 11-12-2007 10:59 PM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 10:17 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 11:33 AM
