Problems With A New/old Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:15 PM   #1
Problems with a new/old compressor
I have a new/old ingersoll compressor that I have attempted to wire in my shop. the motor is a 15amp 230v. i have done the wiring as listed below but am not getting it to run correctly. when i flip the breaker, the compressor fires up hard and fast but within just a few seconds (maybe 10) it starts to slow and and then trips the motor breaker (not the panel). After about 10 minutes you can set the motor breaker and it will start back up but does the same thing. It does build pressure in the tank but shuts off pretty quick.
at the breaker box i have a double pull 30amp breaker. think thats ok.
from there i ran 10(3) cable to a dryer outlet. not sure on this one...
i rewired the plug on the compressor with a 10(2) cable that then plugs into the dryer outlet.
i replaced the pressure regulator but did not rewire to the motor.
so today i was able to get a clamp meter and tested. here is what i found...
i set the clamp meter to 200v (correct?)
on the black wire i start off with roughly 45.1 amps and then drops to around 41.1 as is starts to slow down.
on the white wire it starts off over 46 and then windes down to around 44.8 right before it stops. i would think this would not be good as it's a 15amp motor. i understand that should allow it double to 30 at the point of start up but it should settle back to around 15 when it's running? not sure how it would hit 40 and not trip the panel but that's what i get.
i did notice this time that wires/motor do get hot - well warm. doesnt really have time to get "hot" before it shuts off. again, makes me think it's a wiring issue.
i was going to try to get the belt loose to run it but had trouble with a couple of bolts so left it for now.
by the way, its a single hump.
if some pictures would help, let me know.!
thanks!!!
boilermanc is offline   Reply With Quote
Old 07-24-2012, 05:14 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
thanks!!!
Take a picture of the nameplate on the motor please.
Old 07-24-2012, 05:32 PM   #3
Electrical Contractor
kbsparky's Avatar
This sounds like you have connected 240 Volts to a motor configured for 120 Volt operation.
But there could be other factors in play here -- as someone else has requested, start with a high-resolution photo of the motor nameplate ...
-KB
Old 07-24-2012, 05:38 PM   #4
A breaker may trip that quickly with a 3x overload.
Heat Pump, dual system, all electric, compressor not working rlc5669 HVAC 16 01-04-2011 07:59 AM
CampBell Hausfeld Compressor problems Hexar Tools 13 11-23-2010 06:23 PM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
