Problems With Kichler Under-cabinet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 06:52 AM   #1
Problems with Kichler under-cabinet lighting
Hello. My kitchen has Kichler under-cabinet lighting, installed by the builder - strings of 12v 10w xenon festoon lamps. It has never worked well in the four years since the house was built: the lamps frequently lose contact with the wire and need to be jostled to light. I understand this is not an unknown problem with this product.
There's nothing obviously wrong with the installation: wires are nestled and lamps are clicked securely in the tracks - but the electrical contact remains flaky. I'm wondering if there's anything I can do to improve the situation - hopefully, short of ripping it all out and replacing with Seagull hardware. Perhaps Kichler lamps have improved from four years ago, or there are third-party products that work better with the Kichler wire/track? Any ideas?
nathanmeyers is offline   Reply With Quote
Old 09-16-2011, 08:04 AM   #2
Lic Elect/Inspector/CPO
These have always been a problem. Many times a take out the old trac and replace it with ambiance lighting.
Ambiance is 12 volt and the ambiance small lights can be place anywhere on the new trac.
You just have to make sure you do not exceed the existing low voltage transformer.
NJMarine is offline   Reply With Quote
Old 09-16-2011, 08:14 AM   #3
Thanks. I would expect to use the same number of lamps - and at least I already have the bulbs. To make sure I understand, the existing cable will be usable with the Ambiance lamps but the track will not?
Old 09-21-2011, 09:55 AM   #4
Hello. I am contacting you on behalf of Kichler Lighting and I see that
you are having problems with the under-cabinet lighting that is
installed in your home. I have notified Kichler and they would like to
help. Please call this customer service number: 1-866-558-5706. You can
also reach out to TechSupport@Kichler.com and include your contact
information so that someone can get back to you in a timely fashion.
Thanks and we look forward to resolving these issues for you.
KichlerLighting is offline   Reply With Quote
Old 09-21-2011, 03:25 PM   #5
This for initiating this - I've sent a note, and look forward to making some progress on this issue.
Nathan
Tags
kichler under cabinet
Another cabinet lighting question bcbud3 Electrical 0 10-25-2010 11:35 PM
Sub cabinet lighting ex-Khobar Andy Electrical 2 03-05-2009 07:48 PM
Under cabinet lighting TonyD Electrical 20 11-08-2007 06:00 AM
under cabinet lighting handifoot Electrical 1 05-25-2006 11:48 PM
