Problems Installing A Light Fixture Onto A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 09:43 PM   #1
Problems Installing a Light Fixture onto a Ceiling Fan
Hi all,
I'm trying to install a light fixture onto a ceiling fan. Instead of black and white wires, the ceiling fan had blue and white in the little box underneath it (along with other colored wires, though blue and white were the only two with the ends available.) I connected the black wire to the blue and white to white. Unfortunately, it doesn't seem to be working. I'm very inexperienced with DIY projects, so any thoughts/help would be greatly appreciated.
I'm including a photo of the set-up (with my light fixture connected) as an attachment to this message so that you can get a picture of the set-up. Thanks in advance!
adk97 is offline   Reply With Quote
Old 08-14-2010, 10:04 PM   #2
Master Electrician
Rewards Points: 3,778
Did you pull the chain on the light fixture and/or put light bulbs in it?
brric is online now   Reply With Quote
Old 08-14-2010, 10:08 PM   #3
Electrician
Proby's Avatar
Did you check the bulbs?
Did you pull the chain?
EDITED brric beat me to these lol.
If so, then you might have to take the canopy off where the fan is attached to the ceiling (this might require you to take the whole fan down) and check the blue wire. Since the fan didn't have a light kit, someone might not have hooked up that light wire. If it is just loose up there, then you need to connect it to the two black wires that are already spliced together.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-16-2010, 04:05 AM   #4
Thanks for the replies, my apologies for not replying back sooner myself. I did check the light bulb and chain. It sounds like the problem is likely in the ceiling fan connection then? I may attempt to take it down myself sometime this week, or I might call in outside assistance. I have not yet decided. Either way, thanks again!
Old 08-16-2010, 06:30 AM   #5
dSilanskas's Avatar
Take the fan down and make sure that the blue wire is also connected to the black. Sounds like they didn't attach it when the fan was installed.
dSilanskas is offline   Reply With Quote
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 02:01 PM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 05:44 PM
Light fixture in a drop ceiling? kosherdill Electrical 1 03-01-2009 01:23 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 12:33 PM
Ceiling Light problems David Cleere Electrical 9 07-17-2007 07:13 PM
