12-06-2007, 12:38 PM
#1
Problems with Drilling through celing joists
I am doing an engineering project in school and would appreciate it if you could help me. please answer the survey to the best of your ability.
Have you ever had to run wiring from a power source through a finished area in your house to install a light, ceiling fan, speakers, etc.?
Describe the method you used.
Did you have to drill through joists or studs?
How much drywall did you have to cut away?
If the hole(s) was large, was it difficult to patch it?
Is it very noticeable?
Would you be willing to buy something that could drill through the joists with out cutting a large hole or multiple holes?
Thank you for your time.
12-06-2007, 04:05 PM
#2
Electrician philosopher
1.Yes, all the time
2. Mad skills and fishing poles.
3.Yes.
4. None
5. No.
6. No.
7. No
Andy
12-06-2007, 06:30 PM
#3
You talking to me?
Yes and a drill, duh!. Just kidding. I currently have some Irwin auger drills that drill through wood like a hot knife through butter.
as little as possible
No more so than a small hole. It's just work.
? Nope
Sometimes it is inevitable. I have a 5 foot flexi drill bit that helps keep the rock cutting down to a minimum.
You're welcome
12-06-2007, 07:36 PM
#4
" Euro " electrician
A. Sure we have to do that anyway.
A. Just enough to get the bit in.
A. not really it depending if drywall or plaster/lathe set up. the latter is more tougher to get it even.
A. it depending on the location where i breech it.
A. yes i have the fixable drill bit with 1.5 meter shaft to drill in the wall/ceiling cavity. and have extendsion as well to make it longer if needed [ the extendison is work best with vertical walls but ceiling every other joints or third one depending on the setup.
De Rein [ you are welcome]
Merci, Marc
12-07-2007, 08:58 AM
#5
Yes
I try to string the wire up next to a vent pipe, I use a stud boring 1/2" drill bit that's 3' long, or a flexible 5' bit that lets me cut a small opening in a wall, and bend it up through the top or bottom plate, etc. just like
but my bit lets me attach a handle to help bend & direct it.
Yes
Just enough, and try to make sure it's rectangular.
Almost as easy repairing a large hole as it is a small.
No
I think it probably as easy as it's going to get unless robotics happens with just those 2 types of drill bits, I'm not one who likes to overdo it on the tools so most likely I would not unless the product really simple and innovative for such tasks.
You're Welcome
12-07-2007, 07:02 PM
#6
yes
from the in wall switch through the attic to an UL approved box at the desired location.
studs only!!! drilling through ceiling joists could weaken the structure and thats not good
ussually only for the box(es)
no
no if done proberly with spackle
there is no such tool that would ever make me drill through a joist.
12-07-2007, 07:52 PM
#7
Huh??  Engineered truss, in some cases. Joist, gonna need to see some evidence.
Andy
12-08-2007, 07:22 AM
#8
Licensed Electrical Cont.
Holy Crap! If this is not a build up to a spam post nothing is.
If anything this is market research for the company he works for or owns.
I refuse to take part.
Hell, his screen name is even " XXX Inc."
Sure, he's in school. The same school we are all in.
12-08-2007, 07:33 AM
#9
I thought that too, SP. But hell, now I'm kinda curious...
12-08-2007, 11:29 AM
#10
I hate to be such a cynic, but I calls 'em as I sees 'em.
12-10-2007, 11:40 AM
#11
This survey is for a class i am taking in high school. it is part of a engineering course called Project Lead the Way. this year we have to find a problem, research and find justification (which is what this survey is) and attempt to create a prototype for a solution to the problem. JIT inc stands for the members of my group John, Tony and me, Ismail. i am sorry if you think this is spam but this was the only way i could find research/ justification for this problem. i would really appreciate it if you could help me. you can contact me at jitinc@yahoo.com. thank you.
12-10-2007, 05:15 PM
#12
Do you feel guilty now, Speedy  ? I am officially rolling on the floor. Now I suppose I have to go back and answer the questions correctly?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
