Old 10-14-2012, 06:12 PM   #1
Problems with dimmer switch
I have a pain in the butt dimmer question. I recently bought a house and want to upgrade the lights. I bought a replacement Leviton dimmer to replace and old dial style dimmer (probably installed when the house was built in 84). It is a three way switch with 2 flood lights for a basement. I successfully replaced the dimmer however;
When I dim the lights to the lowest levels, one of the lights blinked so i replaced the bulb with a new Philips dimmer bulb (compact florescent) 20w 120 v as the blinking bulb was not dimmer rated.
Now when I dim the lights there is a loud buzzing noise.
I don't understand what could now be wrong. Other than I should be using incandescent bulbs?
BandE is offline   Reply With Quote
Old 10-14-2012, 08:01 PM   #2
Electrical Contractor
Was the dimmer rated for CFL's?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-15-2012, 09:44 AM   #3
The salesperson indicated that the dimmer switch would work fine as the bulbs are CFLs and designed to replace incandescent bulbs. However it is stamped on the dimmer incandescent only.
Old 10-15-2012, 08:13 PM   #4
Went and got a CFL dimmer, the bulb still buzzes when dimmed....
Old 10-15-2012, 10:15 PM   #5
Did the light bulbs also say dimmable?
Old 10-16-2012, 12:46 AM   #6
" Euro " electrician
frenchelectrican's Avatar
What the model number of that dimmer switch is ??
And what ya did with the other three way switch left it alone or what ?
Merci,
Marc
Old 10-16-2012, 08:33 AM   #7
Joecaptian,
Yes it is a CFL dimmable bulb which is buzzing. It gets louder as the lights are dimmed. If I swap out the buzzing bulb put a non-dimmable light bulb in the socket it stops buzzing (but doesn't dim well). I'm thinking I've got a bad dimming bulb.
FrenchElectrician
The CFL dimmer switch I installed was a Lutron Diva, I had replaced the other 3 way switch that controls the same lights with a standard 3 way on/off switch.
Old 10-16-2012, 01:38 PM   #8
Lutron publishes a list of bulbs that they have tested for compatibility.
http://www.lutron.com/TechnicalDocum..._Bulb_list.pdf
They only suggest bulbs that have been tested and deemed compatible. If your bulb is not on the list and/or one on the list is buzzing, you can contact Lutron Technical Support 24/7 at 800-523-9466 .
Oso954 is offline   Reply With Quote
wiring a digital dimmer switch albertlayden Electrical 8 01-27-2012 07:33 PM
replacing an existing 1-way decora light switch with a dimmer switch maljeff Electrical 3 01-11-2012 12:49 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
