Problems With Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2006, 06:42 PM   #1
Problems with breaker box
What could cause the main breaker in my breaker box to trip? I have a 100 amp breaker box with six 20 amp single pole breakers, two 30 amp double pole breakers, and one 50 amp double breaker. running a 120 volt monitor heater, washer, deep freezer, frig, two tv's, one computer, lights, with 220 volt 3/4 horsepower well, electric stove and hot water heater in a 6 room house. Also have a vented oil stove in the back room which has a blower on it. Does any of this help?
whitepa254 is offline   Reply With Quote
Old 02-15-2006, 07:05 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
A bad connection at the stab behind the breaker is the most common cause I see.
Is the breaker real hot, even though the load is moderate?
Speedy Petey is online now   Reply With Quote
Old 02-15-2006, 07:26 PM   #3
problem with breaker box
Im not sure what moderate is but when im using the washer and stove it does get hot and I think, if I remember right it gets hot by just running the washer.
Old 02-15-2006, 07:40 PM   #4
Old 02-15-2006, 09:03 PM   #5
Moderate is half of the house running. From your description I would be concerned.
Please call an electrician. The main breaker is no place for a DIY to be messing around.
Old 02-16-2006, 04:28 PM   #6
Does this mean I will have to replace the breaker box?
Old 02-16-2006, 08:58 PM   #7
Possibly. Actually likely.
If the breaker stabs are burned and corroded then a new main breaker alone will do no good as it would have to attach to those bad stabs.
Old 02-16-2006, 09:24 PM   #8
problems with breaker box
:o My house is an old house and use to have a fuse box which held four screw in fuses and two push in type if you know what I mean. four for 120 and two for 220. It was switch out and a 100 amp breaker box put in. When it was switch the house was rewired but the wire from the meter to the box and from the power company pole to the meter was not. What are your feelings about this. I think I forgot to mention this before and it may change what you told me before. Also what is your opinion about changing the 100 amp breaker box to a 200 amp box. Will these other wires I mentioned have to be changed also?
Old 02-16-2006, 10:37 PM   #9
I would have never gone from a fuse panel to a breaker panel without replacing everything. The age of anything from the fuse era would alone warrant replacement.
For a service upgrade everything from the taps at the top of the service, down to the panel, breakers and grounding/bonding, must be replaced. Depending on your area a 200a upgrade could run anwhere from $1200-$2500.
Depending on the size of your house, actual circuits and load, and more importantly future plans, 200 amps might not be a bad idea.
Old 02-17-2006, 04:53 AM   #10
Thanks. You been very helpful and to anyone else who is living in the upstate NY area and reading this I would highly recommend speedy petey for any electrical work that you may need done.
Old 02-18-2006, 02:37 PM   #11
You're quite welcome, and thank you!
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
GFCI breaker problems bwoo Electrical 5 12-09-2006 02:53 PM
Breaker Problems tonymull Electrical 12 03-30-2005 04:11 PM
