-   -   Problems with breaker box (http://www.diychatroom.com/f18/problems-breaker-box-1878/)
whitepa254 02-15-2006 07:42 PM
:mad: What could cause the main breaker in my breaker box to trip? I have a 100 amp breaker box with six 20 amp single pole breakers, two 30 amp double pole breakers, and one 50 amp double breaker. running a 120 volt monitor heater, washer, deep freezer, frig, two tv's, one computer, lights, with 220 volt 3/4 horsepower well, electric stove and hot water heater in a 6 room house. Also have a vented oil stove in the back room which has a blower on it. Does any of this help?
Speedy Petey 02-15-2006 08:05 PM
A bad connection at the stab behind the breaker is the most common cause I see.
Is the breaker real hot, even though the load is moderate?
whitepa254 02-15-2006 08:26 PM
problem with breaker box
Im not sure what moderate is but when im using the washer and stove it does get hot and I think, if I remember right it gets hot by just running the washer.
whitepa254 02-15-2006 08:40 PM
Speedy Petey 02-15-2006 10:03 PM
Moderate is half of the house running. From your description I would be concerned.
Please call an electrician. The main breaker is no place for a DIY to be messing around.
whitepa254 02-16-2006 05:28 PM
Does this mean I will have to replace the breaker box?
Speedy Petey 02-16-2006 09:58 PM
Possibly. Actually likely.
If the breaker stabs are burned and corroded then a new main breaker alone will do no good as it would have to attach to those bad stabs.
whitepa254 02-16-2006 10:24 PM
problems with breaker box
:o My house is an old house and use to have a fuse box which held four screw in fuses and two push in type if you know what I mean. four for 120 and two for 220. It was switch out and a 100 amp breaker box put in. When it was switch the house was rewired but the wire from the meter to the box and from the power company pole to the meter was not. What are your feelings about this. I think I forgot to mention this before and it may change what you told me before. Also what is your opinion about changing the 100 amp breaker box to a 200 amp box. Will these other wires I mentioned have to be changed also?
Speedy Petey 02-16-2006 11:37 PM
I would have never gone from a fuse panel to a breaker panel without replacing everything. The age of anything from the fuse era would alone warrant replacement.
For a service upgrade everything from the taps at the top of the service, down to the panel, breakers and grounding/bonding, must be replaced. Depending on your area a 200a upgrade could run anwhere from $1200-$2500.
Depending on the size of your house, actual circuits and load, and more importantly future plans, 200 amps might not be a bad idea.
whitepa254 02-17-2006 05:53 AM
Thanks. You been very helpful and to anyone else who is living in the upstate NY area and reading this I would highly recommend speedy petey for any electrical work that you may need done.
Speedy Petey 02-18-2006 03:37 PM
You're quite welcome, and thank you!
