Problems With AC Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 12:29 AM   #1
Problems with AC breaker
I had a fan replaced in my HVAC unit. The technician had a hard time and tripped the circuit at least 30 times before he could get the fan wired correctly. Now the AC works for awhile and then the breaker gets hot and trips (although the switch itself doesn't move). I can get the ac running again if I trip the circuit a few times - the circuit breaker is probably forty years old - any chance the breaker is just bad??
samnewt is offline   Reply With Quote
Old 09-04-2011, 01:47 AM   #2
Thadius856's Avatar
Rewards Points: 504
Sounds bad to me, especially if you have to trip it several times.
If the breaker is 40 years old, I can't imagine that it costs much more than $10 to replace...
Give it a try.
Thadius856 is offline   Reply With Quote
The Following User Says Thank You to Thadius856 For This Useful Post:
samnewt (09-04-2011)
Old 09-04-2011, 07:08 AM   #3
Rewards Points: 1,192
Where did you get this "tech" from and you did not pay him yet?
bobelectric is offline   Reply With Quote
Old 09-04-2011, 08:44 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If he tripped the breaker electrically that many times he may have well made it toast. It may or may not be easy to find a replacement for a 40 year old breaker, some brands are no longer in business. Some older brands are available on the secondary market but usually are not cheap. Post the brand and panel ID and you will get some help.
Coastal South Carolina
Old 09-04-2011, 08:48 AM   #5
I=E/R
a7ecorsair's Avatar
Maybe it is still wired incorrectly or maybe even the wrong fan.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Code05 (09-04-2011)
Old 09-04-2011, 08:39 PM   #6
Missouri Bound's Avatar
Get a new breaker and a new "technician" One or two trips....even three when trouble shooting isn't the worst thing....but 30 times is the sign of someone in over their heads on the repair. Your lucky the smell of smoke didn't come with this "service" call.
Old 09-04-2011, 09:17 PM   #7
Code05's Avatar
Rewards Points: 1,104
Sounds like a handyman special.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
frenchelectrican (09-04-2011)
Old 09-04-2011, 10:33 PM   #8
" Euro " electrician
frenchelectrican's Avatar
30 Times to reset the breaker that is conneries.,,, that is a perfect way to destory the breaker like that.
More like a handyman person have no bussiness to work on that unit.
As other mention a well trained person may trip once maybe twice even myself it did happend but kinda rare due I double check my work before I engerized the system.
Merci,
Marc
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 11:53 AM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
GFCI breaker problems bwoo Electrical 5 12-09-2006 03:53 PM
Breaker Problems tonymull Electrical 12 03-30-2005 05:11 PM
