Problems With A 220 Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 01:38 PM   #1
problems with a 220 circuit
Hi,
A few days ago I installed a new 110 circuit to add some lights and a fan. The box was a bit tight and the new breaker had to go at the bottom so it was easier to route if I popped off the upper ones an swung them to the side.
I reinstalled everything and restored power and everything seemed fine, except 36 hours later I had no hot water, zero. I pulled the panel on the heater and tested the red and black lines going to the main block and got 0 volts instead of 220. I went back to the panel and tested between the two circuit breakers and got zero. when I test between either of them and ground, I get 110, but between them, 0.
I'm far from expert but it seems as if I wired them out of phase or something. The two GE breakers in the circle are for the WH circuit. I'm pretty sure I connected them back to the same lugs they were on, but not 100% on it. The gap above them seems a bit odd. On the left of it there is a grab lug to hold the back of a breaker, but there is no connector lug in the center so I don't see how a breaker could go there.
Any ideas what I'm doing wrong here? I really need a hot shower
Thank You,
Eric
http://farm3.static.flickr.com/2432/...7c0e23e2_o.jpg
everyman is offline   Reply With Quote
Old 06-25-2009, 01:45 PM   #2
DIY'r
ScottR's Avatar
Dupe of: problems with a 220 circuit
ScottR is offline   Reply With Quote
circuit breaker problems nascarstewartfan2007 Electrical 8 09-13-2015 09:11 AM
problems with a 220 circuit everyman Electrical 12 06-25-2009 03:11 PM
Circuit problems Bobby55 Electrical 3 01-29-2008 09:45 PM
Circuit Problems - Garage DisturbedPanda Electrical 9 08-03-2007 09:23 PM
