Problem With Wiring...celing Fan/switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2008, 09:40 PM   #1
problem with wiring...celing fan/switch
I encounterd a problem...i wired up my celing fan incorrectly and now the switch doesn't work...when i hooked up the fan i accidently put the "Light"(blue) wire to the the "White" common wire, the "Light" (Blue) wire was suppose to be connected to the "Hot" (black) wire...Now my delima is the switch doesn't work...i dont think there is power going through the wiring, and i picked up a illuminecent light switch...the switch doesn't light up...the hall way light doesn't work also and i think the halway switch is connected to my celing switch......i replace all the switches and nothing goes on still...
what is my problem and what do i do to fix it?
Thank you very much....I'm a drywaller not an electritian...so thank you for your ear and your advice...
Jensen Hernandez
anywhofaq is offline   Reply With Quote
Old 05-08-2008, 09:52 PM   #2
Master Of Nothing
mr500's Avatar
Have you checked the breaker to make sure its not tripped? I would turn it off then back on again just to make sure. If there is NO power then it has to be traced back to the panel. Check the breaker for that circuit.
Problaby will have a red square next to the breaker to show it has tripped.
Also, are there any GFi;s in line with this switch? Might check the ones you have just to make sure none are feeding the switches.
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 05-08-2008, 09:59 PM   #3
checked the breaker
yeah i turned it off and on mutiple times...the breaker that is connected to my room is also connected to another room...all other electrcal outlets work...the other room's celing fan switch works...what would be another altreitive...i dont think there is anoter GFCI in another area besides the circutbreaker box...
should i mention the smoke detector went off when i switched the switch to the on position...
Old 05-08-2008, 10:15 PM   #4
Master Of Nothing
mr500's Avatar
There will be a GFI plug in the kitchen as well as bathroom. Bathrooms are suppose to be on a separate circuit, BUT I would check to see if it is tripped or at least that the plugs in those areas work. Never can tell how it was wired up.
Did you check for power at the fan and/or at the switch with a meter? I know you said that there was no power, just asking if thats an assumption or if you checked with a meter.
Other than that im little baffled. But them Im not electrician lol. Im sure one will chime in on this and find your problem!!
Old 05-08-2008, 10:17 PM   #5
the new switched i installed has an illuminecent light on the top of the switch....and it is is not lighting up
Old 05-08-2008, 10:52 PM   #6
Master Of Nothing
mr500's Avatar
It is suppose to yes, and it probably works, I was just saying I would check power anyway just to make sure.
I don't think that you broke the breaker lol, but I guess anything is possible, but I would trace out everything before i swapped out the breaker.
Other than that, im baffled.. Someone will chime in im sure!!
Mike
Old 05-08-2008, 11:04 PM   #7
Talking
thanx mike
thanks mike for your help....i really appreciate it
Old 05-09-2008, 07:58 AM   #8
Licensed Pro
Did you correct the wiring at the ceiling fan? Did you disconnect any wires at that box, or not reconnect them properly? Since that is where this all started, I'd check there first.
Old 05-09-2008, 04:20 PM   #9
still yet
I took the fan down and put my old light back up and still no juice...i checked the circut breaker...the circut breker for the 2 rooms are good...all the outlets work fine.
Dryer on the fritz.. wiring problem? cisco10 Electrical 17 11-19-2009 01:26 PM
diagnose house wiring problem brhodewalt Electrical 7 05-06-2009 09:03 PM
trailer wiring problem dns Automotive Repairs 2 10-09-2007 02:50 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 09:22 AM
