Problem W/ Power After Switching Outlets... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2006, 08:30 PM   #16
Lowly College Student
J187, When i test the power I test all 4 wires in every outlet, not just one outlet. I also test the wires and not the actual recepticle.
I will be spending most of the day tomorrow messing w/ this problem. I will work from ground zero start all over again.
One other thing, has anyone ever heard of a tool that uses electrical induction to see if there is electricity through the wall? I was talkin to a friend and he said that there is a tool that can locate running current through wires through the wall. This would definately help me in my endeavor as I would know which wall to start at and not have to tear down possible 2 walls...
Any input is apprcieated.
Thanks Again.
G19-Fanatic is offline   Reply With Quote
Old 08-23-2006, 09:15 PM   #17
joed's Avatar
Rewards Points: 13,712
here's one for $370.
http://www.constructionbook.com/xq/A...x/default2.htm
Here is a bunch more.
http://www.professionalequipment.com...qx/default.htm
Old 08-28-2006, 01:55 PM   #18
may be when you test the voltage, did you remove all outlets before testing? may be a misconnect somewhere affect your testing result if you don't do that... I will say pigtails all wire... no outlets connected anywere, then measure the black wire one by one... find the real hot one, then go from there...
KUIPORNG is offline   Reply With Quote
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 07:12 PM
ceiling fan and gfi conflict toolsnstuff Electrical 2 01-29-2007 06:51 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
