Problem With Power - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 08:49 PM   #1
Problem with power
Have a very strange problem. It started with our dryer not working all of a sudden. Thinking it was the dryer then found out the oven didn't work also. (both on the same breaker). Instantly figured it was the breaker. Replaced it, and still nothing.
Tested the voltage in BOTH outlets. Full power. Now both the dryer and oven have Power Failure flashing, and I don't know what to do. Tried everything with the breaker wires. Tried running the dryer without the oven, and vice versa, and nothing.
The dryer is getting some power. When I hit the power button it flashes on really quick but shuts off. The oven, clock works, timers work, just no heat.
I'm running out of ideas.
colu41 is offline   Reply With Quote
Old 06-13-2011, 08:53 PM   #2
Electrician
Rewards Points: 770
First off are you sure they are on the same breaker, these two items should have a dedicated circuit.
How did you test your devices. You should be testing for voltage, 240V between the two hots(red and black) and 120 from black and red to ground and neutral.
Since you say your timers work, my first guess would be that you lost one of your hots.
Test both hots to ground or neutral and see if you get 120V from each.
darren is offline   Reply With Quote
Old 06-13-2011, 08:57 PM   #3
Well its a double circuit. 40a to each. And yes, I tested for 240 volts.
Old 06-13-2011, 09:19 PM   #4
Electrical Contractor
kbsparky's Avatar
Originally Posted by colu41 View Post
.... And yes, I tested for 240 volts.
Did you test for a good neutral? Both of those appliances have controls that operate on 120 Volts ...
-KB
Old 06-13-2011, 09:36 PM   #5
Electrician
Rewards Points: 770
You should have a 2Pole for the stove and a seperate 2pole for the dryer. The dryer is usually 30A and the stove is either 40A or 50A. One breaker should not turn off both.
Old 06-14-2011, 08:36 AM   #6
I=E/R
a7ecorsair's Avatar
What, may I ask, is a double circuit?
a7ecorsair is offline   Reply With Quote
Old 06-14-2011, 04:20 PM   #7
I guess I failed to mention I live in a trailer home. The breakers are much different I think.
I guess I call a "2 pole" double circuit :/ but yes, the oven and dryer run on one 2 pole breaker. Always has. Lived here for almost 5 years.
Old 06-14-2011, 08:17 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,100
Sounds like you might have a loose connection some where !
this is limiting the current available,
With a light load there would be little loss,
which is why the meter read ok !
but put a serious load on,
and now the loss is now substancial.
Burnt out contacts, faulty wire, loose conections.
dmxtothemax is offline   Reply With Quote
Old 06-15-2011, 04:56 PM   #9
in my homes electrical itself? Because tthat won't explain why the oven doesn't work either.... wondering if maybe I got some sort of power surge and it just blew out a fuse or wire in the oven and dryer...not sure
Old 06-15-2011, 05:21 PM   #10
I=E/R
a7ecorsair's Avatar
The control panel is most likely a 120 v part of the appliance so an open neutral somewhere in that daily chained circuit could affect only these two appliances. You will have to start at the panel board (circuit breaker box) and then the two connection points for the appliances and check for loose or corroded connections.
Old 06-15-2011, 05:33 PM   #11
Well I did check the breaker, and actually bought a new one thinking that was it.
Old 06-15-2011, 08:43 PM   #12
Rewards Points: 1,440
Are you getting 240 volts at the dryer receptacle? Are you getting 240 volts at the overn receptacle or junction box?
Old 06-15-2011, 09:03 PM   #13
Im getting 240 at both outlets. BUT. I tested the leads on the back of the dryer. I get 120 on one side and 50 on the other. But when I disconnect the black wire, it measures 120.
So. From the black wire to neutral I get 50, and red to neutral get 120. But when I disconnect the black wire from the back of the dryer, I get 120.
Intermittent Brief Power Outages in Half the House mac70pete Electrical 11 06-02-2011 10:35 PM
power to "half" the house dogvila Electrical 8 07-13-2010 10:04 PM
No power to all outlets on circuit. noloawarfare Electrical 4 05-01-2010 05:41 PM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
