Problem With My New Dimmer's Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 04:09 PM   #16
DIY staff
Rewards Points: 7,174
Could you tell us the brand and model of that dimmer---?
Old 03-25-2013, 04:25 PM   #17
Insteon 2477D
Barrymwf is offline   Reply With Quote
Old 03-25-2013, 04:50 PM   #18
Electrical Contractor
jbfan's Avatar
Rewards Points: 472
http://www.idealindustries.com/prodD...v=0&l1=push-in
These
jbfan is online now   Reply With Quote
Old 03-25-2013, 06:45 PM   #19
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The box is already bonded, in your scenario the switch is bonded through the 6-32 device screws, you dont need to do anything with the ground wire on the actual switch.
Old 03-26-2013, 01:09 AM   #20
Rewards Points: 512
Originally Posted by Barrymwf View Post
U said I should correct the grounding in the box, how do I do it now as the two ground wires at the end of the box are way too short?? Please suggest!!
Thank you so much!
There is a bare copper stranded wire in your first pic. Where is that going to/coming from?
Old 03-26-2013, 01:13 AM   #21
Rewards Points: 512
Perhaps this will help?
Old 03-26-2013, 05:42 AM   #22
Rewards Points: 2,516
Hey batman that diagram was in the manual. Didnt the poster look at the manual??
Cannot get any clearer than that.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
sirsparksalot (03-26-2013)
Old 03-26-2013, 12:04 PM   #23
Rewards Points: 150
The OP's situation is a little different than just read the manual. He has a 2nd black wire on one screw of the old switch and a 3rd white in his bundle of neutrals. The new switch has no screws to affix those two blacks to. So where you take the two blacks that currently affix to one screw off the old switch, those you would wire-nut together with the black wire instead. So unlike the manual which shows just one black connecting to the switch black, you'll have two. This extra black and 3rd neutral takes power to some other switch or outlet elsewhere.
SquishyBall is offline   Reply With Quote
Old 03-26-2013, 12:19 PM   #24
Rewards Points: 512
Just boils down to he needs a pigtail or two.
Old 03-26-2013, 12:41 PM   #25
Thanks everyone I will try to do it.
But I have one more question, can I connect the ground wire of the switch to the screw at the back of the junction box?? Is that way safe or the bare wire on the screw is not even a ground wire??
Old 03-26-2013, 12:52 PM   #26
Rewards Points: 512
Is there already a wire on the screw at the back of the box?
Old 03-26-2013, 01:10 PM   #27
Yes but it's cut and they are extremely short. You could refer to the picture on the first page.
Thank you!
Old 03-26-2013, 01:11 PM   #28
jbfan's Avatar
Rewards Points: 472
Like stickboy said, the box is already grounded, so just the screws on the switch will be fine.
Old 03-26-2013, 01:16 PM   #29
Rewards Points: 512
What JB (and Stickboy) said!!
Old 03-26-2013, 02:34 PM   #30
Thanks I will try it tonight!
Help!! So confused on wiring dimmers! Skylaa Electrical 19 12-12-2011 09:59 PM
Wiring two 3-way dimmers on one breaker drex Electrical 0 09-12-2011 08:54 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Wiring problem datoda Electrical 6 12-28-2009 07:43 PM
Problem with Air Handler wiring connection to Outdoor Unit & Thermostat miamikk HVAC 0 09-29-2009 07:02 PM
