Problem With Motion Sensor Switch & Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 01:18 PM   #1
Question
Problem with motion sensor switch & light
Several years ago, my father installed a motion activated light switch on our stairs. It worked great, until it burned out. My husband tried to replace it with the same type, & it wouldn't work. Yesterday, I again tried to replace the switch with a motion activated. It works fine during the testing/setup phase, but during regular use, it turns on with motion, but does not turn off. All the settings are correct. Oddly, the same thing has happened with a motion sensor light my husband put up outside. After his recent death, I tried putting up 2 motion sensor lights outside. One works fine, the other (the same one he tried) does the same thing as the indoor. It works perfectly while in the setup/testing phase, but after that, when it turns on it won't turn off. My husband & I have both been doing small electrical repairs (switches, receptacles, light fixtures) for many years now, as has my father. None of us have been able to figure out what is wrong or if we are just unlucky enough to keep purchasing defective products. Any ideas?
usseabeemom is offline   Reply With Quote
Old 11-16-2008, 01:35 PM   #2
the Musigician
DangerMouse's Avatar
the ones i installed at our old home did the same thing. there should be a 'time' switch on the bottom to set for 2, 4 or however many minutes until it turns off. if it still fails, disconnect the power for a few minutes to allow it to 'reset' itself and retry. flip the breaker if you have to.
let us know if that works. =o)
DM
Old 11-16-2008, 01:51 PM   #3
Many of these types of swithes have several modes of operation.
Carefully read the directions. Most times you need to turn the switch on and off in rapid succession to change modes. Turning the switch or power to the switch on an off in the regular fassioin will not do anything to the mode.
Sometimes these lights will work great till a storm causes power glitches that cause the power to turn on and off in the same sequence that the mode change would. After such an event you will need to manually reset the mode.
Master Electrician
jwhite is offline   Reply With Quote
Old 11-17-2008, 05:54 PM   #4
I already tried both of these things--several times.
Old 11-17-2008, 06:04 PM   #5
the Musigician
hmmmm, wouldn't be the first time a unit is bad out of the box. where was it made? china?
DM
Old 11-17-2008, 06:54 PM   #6
DM
Ive seen usa things go aswell...My motherboard went along with one of my graphics cards right when I got it!
Luckily I was able to rma it.
Most "made in china" things break...cheap things...
rgsgww is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Help! I have an LED wall lights problem Carter Electrical 5 10-16-2008 11:47 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
wiring motion light two locations donjh Electrical 1 06-13-2008 06:10 PM
