Problem With Line Voltage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2007, 05:10 PM   #16
not today but have done it before and I got 122-125 VAC on each.
mehranalmasi is offline   Reply With Quote
Old 06-27-2007, 06:19 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
That is what's strange. With the motor connected you would get a backfeed on the open line and get a reading. With both lines disconnected from the motor the open line should read zero.
It is possible you have a line open and shorted to the other line.
What exactly is the wiring method from the source (timer, etc.) to the motor? Cable? Pipe and wire?
Old 06-28-2007, 11:38 AM   #18
yes I have done this before and both reading 122-125VAC!
Old 06-28-2007, 11:45 AM   #19
please igonor my last post! its a repeat.
I have a toggle swith placed beofre the timer. From the timer a metal non-flex conduit goes down about 3 feet towards ground and make a 90 degree turn close to concrete surface and runs about two feet to reach the motor. Three wires from the timer, one connected to the timer housing, run through the conduit and to the motor.
After reading your posting, I think I need to open the toggle switch and check the volatage on the wiring that goes into the switch.
thanks.
Old 07-01-2007, 01:53 PM   #20
Rewards Points: 252
Have you tried to take a voltage reading while the pump motor is energized. Should there be a motor issue the high current will reduce the line voltage. Don't test to ground. Test across the two CCC's. (hots). You want to see 220/240 volts AC. Make sure meter is not showing milivolts. Quite common and possibly confusing. Make sure the meter reads VAC not MV.
Old 07-02-2007, 12:11 PM   #21
Thank you all for helping to get to the bottom of this. I measured across the two hot lines on the switch before the timer and the needle moved a bit! Nothing measured on the other side of the switch when I turned it on which was more confusing. I went to the panel and noticed that one of the breakers of the two did not quite look in place. I turned both off and back on and suddenly everything is back to normal!
Mehran
Old 07-04-2007, 06:12 AM   #22
yeah the breaker that looked a bit out of place would have been tripped, they dont move over all the way when tripped, you have to move it to off then back on
ben23 is offline   Reply With Quote
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Problem with Main Line or Not? reibuild Plumbing 2 05-02-2007 10:41 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
