Problem With Lights Surging - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2006, 11:13 AM   #1
Problem with lights surging
The problem I,m having is all the lights in the house are getting brighter than return to normal. I had pg&e come out and check from the pole to the house. They say it not there problem its the house. Where do it start?
ram318 is offline   Reply With Quote
Old 02-16-2006, 11:34 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Is it all the lights in the house or just one circuit? Are you having trouble with any appliances? If it is just one circuit, then check for a loose netural somewhere in the circut. If it is the whole house, look for the loose netural in the panel. If you are not comfortable looking inside the panel, hire an electrician.
jbfan is online now   Reply With Quote
Old 02-16-2006, 12:41 PM   #3
electrical
I have a 55 inch tv with a filter and surge protector. It too kept shutting down also I have a floor lamp that surges too. I think it all of the electrical.
Old 02-16-2006, 09:01 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Call an electrician ASAP!!!
If the POCO didn't find anything it is in your wiring. Most likely the meter pan. I have had many cases where the neutral simply corroded off inside the meter pan. VERY BAD for the things in your house.
I would unplug EVERYTHING electronic until this is fixed. Even the microwave.
Old 02-22-2006, 06:06 PM   #5
thanks
Thank you guys for the quick response. The problem ended up being on the pole. I believe it was a neutral wire. He said that you couldn't see it but when he put a load on it showed up. Thanks again for the help.
Old 02-22-2006, 07:01 PM   #6
Glad you got it fixed without any damage.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
