Problem Installing U-shaped Fluorescent Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 11:41 AM   #1
Problem installing u-shaped fluorescent bulb
I'm a brand-new widow, trying to do things I have not done before, and would appreciate your help. The new u-shaped fluorescent bulbs I bought to replace the fading ones in my kitchen ceiling lamp are the same brand and model number as the previous ones. I inserted the prongs into the plug end of the fixture, and pressed the body of the bulb into the u-shaped metal clip which should support it at the other end of the fixture. But they were just a little too loose to stay in place. (Picture a zillion glass fragments on my kitchen floor.) Should I try to tighten the metal clip by squeezing with pliers? (Before inserting new bulbs.) Do I need a new fixture? What would you recommend? Is this a common problem? Thanks for your help.
carAitch is offline   Reply With Quote
Old 08-09-2011, 12:12 PM   #2
Rewards Points: 6,652
I usually will check holding clips before I let go, and end up with a disaster. Common sense says to check holding devices when ever you do something, especially lighting.
Old 08-09-2011, 12:26 PM   #3
Licensed electrician
Rewards Points: 1,024
You can probably tighten the clip with your fingers.
carAitch (08-23-2011)
Tags
fluorescent bulbs , light fixture
Problem installing entry door Jemo Building & Construction 19 09-13-2015 08:50 PM
Problem Installing Toto Aquia on Closet Flange on Floor herbolaryo Plumbing 5 07-20-2007 09:32 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Installing GFI problem franko Electrical 3 12-07-2006 03:57 PM
