Problem Installing Exterior Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 10:14 PM   #1
Problem installing exterior light fixture
The existing light fixture by our front door was pretty dated so I decided to purchase a new one. From the picture below, the previous owner installed a pancake box (I have since removed it) for the exising light. The problem I'm having is that if I use the pancake box with the new fixture it sticks out too far from the outside wall, leaving about a 3/4" gap between the wall and the back plate of the light fixture. I'm not sure what my options are at this point. It's too big of a gap to run silicone sealer around the backside of the new light fixture if I install it this way. Any ideas on what else I can do aside from cutting a hole and installing a recessed box? Is there anything I can put between the back plate and the new fixture to fill the gap?
Thanks for any help.
Lynch is offline   Reply With Quote
Old 08-14-2010, 10:30 PM   #2
Electrician
Proby's Avatar
You can use this siding block: http://www.amazon.com/SIDING-MOUNTIN.../dp/B000KKHUEO
The image is incorrect. This siding block is specified as flat, it doesn't have the notches on the back for the siding. You can see it here, it's the 8161: http://www.aifittings.com/k_6.htm
Personally, I would just cut in a box and be done with it. I think it would look better and cost less. it's very easy to do.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-15-2010, 08:54 AM   #3
Thanks Proby. I saw one of those siding blocks when I was at Menards yesterday. Not a bad option but I think I may just cut a hole and put in a box. Not having done this before and a little apprehensive on cutting a hole into an exterior wall, do you have any tips?
Old 08-15-2010, 09:12 AM   #4
Electrician
Proby's Avatar
Well, you are going to need to use a metal box, so unfortunately you can't take advantage of the many old work plastic boxes.
It looks like there is a hole in the center of the circle, I would stick a piece of bent wire into the hole to feel around for a stud. If there is a stud, you can just cut out the sheathing and mount a pancake box to the stud.
Old 08-15-2010, 10:40 AM   #5
Licensed electrician
Rewards Points: 1,240
Could you post a pic of the fixture? That might give someone else an idea. It seems unusual to have a 3/4" gap when the box is only 1/2" deep.
Old 08-16-2010, 11:04 AM   #6
I'll post a few pics tonight to give you a better idea. The main problem as to why it sticks out so far is the mounting bracket for the new lamp that connects to the pancake box, it doesn't recess into the box so it sticks out further. The pictures I'll post later tonight will give you a better idea.
Old 08-16-2010, 02:22 PM   #7
Electrician
Proby's Avatar
If it sticks out any further than the face of the box, then the fixture will not sit flush on the wall when hung from a normal surface mounted box.
Old 08-16-2010, 09:32 PM   #8
Ok, here's some more pics.
1. The original light fixture:
2. Original pancake box with original mounting bracket:
3. Original pancake box with new mounting bracket (Front view)
4. Original pancake box with new mounting bracket (Side view)
5. Backside of new light:
6. New light with existing pancake box and new mounting bracket. I've adjusted the 2 mounting screws from pic 4 to recess as far in as I can.
As you can see it sticks out a good 3/4" from the wall. I don't know if I have any other option at this point than to cut a hole in the wall and mount a box inside the wall. Again, I'm pretty reluctant to do this as I have no experience doing this kind of thing but I'm willing to learn! Why is it that a seeminly simple job is never as easy as it should be
Thanks again guys for any input!
Old 08-22-2010, 09:05 PM   #9
Anyone else offer some ideas/help?
Old 08-22-2010, 09:16 PM   #10
Electrician
Proby's Avatar
Last sentence of Post #2
Old 08-23-2010, 03:06 AM   #11
" Euro " electrician
frenchelectrican's Avatar
I will suggest that you buy a old work juction box and that will really set it back nice and you will not have anymore issue with it or get a oldwork pancake box { little hard to find it } but best is old work steel box due you have BX cable there.
Before you sink in a box make sure you don't hit the stud if you do the pancake box will be the best item you can use.
Merci.
Marc
Old 08-24-2010, 09:13 PM   #12
Thanks for the idea french. I like the idea of using an old work box but am having a heck of a time finding a metal one that will work with BX cable. A round one would work best because of the mounting bracket for the light but I can't seem to find one anywhere! The plastic round old work boxes are readily available but that wouldn't work for BX cable as it needs the ground of a metal box, correct? Any idea where I can find a metal round old work box?
The closest thing I've found so far is this:
Old 08-24-2010, 09:27 PM   #13
Here a link or two what the old work box with 1/2 inch KO so you can use the BX cable.
The first one only if you have no stud behind then you can use this one.
http://www.lowes.com/pd_74219-427-50..._?rpp=15$No=15
I have to find a photo for old work pancake box with support ears so it will be a little while and I know not very many places will have this kind of item.
Merci.
Marc
Old 08-24-2010, 09:29 PM   #14
The photo you posted that will work just fine as well.
Merci.
Marc
Old 08-25-2010, 07:25 AM   #15
Perhaps another option to consider is to add a 3/4" thick decorative trim plate around the existing box, filling the gap between the fixture and wall.
oberkc is offline   Reply With Quote
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Installing Lighting Fixture lilsara88 Electrical 3 01-03-2009 09:49 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Installing a new light fixture shorteared Electrical 2 12-27-2008 03:28 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
