-   -   Problem installing exterior light fixture (http://www.diychatroom.com/f18/problem-installing-exterior-light-fixture-78797/)
Lynch 08-14-2010 09:14 PM
The existing light fixture by our front door was pretty dated so I decided to purchase a new one. From the picture below, the previous owner installed a pancake box (I have since removed it) for the exising light. The problem I'm having is that if I use the pancake box with the new fixture it sticks out too far from the outside wall, leaving about a 3/4" gap between the wall and the back plate of the light fixture. I'm not sure what my options are at this point. It's too big of a gap to run silicone sealer around the backside of the new light fixture if I install it this way. Any ideas on what else I can do aside from cutting a hole and installing a recessed box? Is there anything I can put between the back plate and the new fixture to fill the gap?
Thanks for any help.
http://i684.photobucket.com/albums/v...00814-2033.jpg
Proby 08-14-2010 09:30 PM
You can use this siding block: http://www.amazon.com/SIDING-MOUNTIN.../dp/B000KKHUEO
The image is incorrect. This siding block is specified as flat, it doesn't have the notches on the back for the siding. You can see it here, it's the 8161: http://www.aifittings.com/k_6.htm
Personally, I would just cut in a box and be done with it. I think it would look better and cost less. it's very easy to do.
Lynch 08-15-2010 07:54 AM
Thanks Proby. I saw one of those siding blocks when I was at Menards yesterday. Not a bad option but I think I may just cut a hole and put in a box. Not having done this before and a little apprehensive on cutting a hole into an exterior wall, do you have any tips?
Proby 08-15-2010 08:12 AM
Well, you are going to need to use a metal box, so unfortunately you can't take advantage of the many old work plastic boxes.
It looks like there is a hole in the center of the circle, I would stick a piece of bent wire into the hole to feel around for a stud. If there is a stud, you can just cut out the sheathing and mount a pancake box to the stud.
Jim Port 08-15-2010 09:40 AM
Could you post a pic of the fixture? That might give someone else an idea. It seems unusual to have a 3/4" gap when the box is only 1/2" deep.
Lynch 08-16-2010 10:04 AM
I'll post a few pics tonight to give you a better idea. The main problem as to why it sticks out so far is the mounting bracket for the new lamp that connects to the pancake box, it doesn't recess into the box so it sticks out further. The pictures I'll post later tonight will give you a better idea.
Proby 08-16-2010 01:22 PM
If it sticks out any further than the face of the box, then the fixture will not sit flush on the wall when hung from a normal surface mounted box.
Lynch 08-16-2010 08:32 PM
Ok, here's some more pics.
1. The original light fixture:
http://i684.photobucket.com/albums/v...00816-1939.jpg
2. Original pancake box with original mounting bracket:
http://i684.photobucket.com/albums/v...00816-1940.jpg
3. Original pancake box with new mounting bracket (Front view)
http://i684.photobucket.com/albums/v...00816-1944.jpg
4. Original pancake box with new mounting bracket (Side view)
http://i684.photobucket.com/albums/v...00816-1945.jpg
5. Backside of new light:
http://i684.photobucket.com/albums/v...00816-1956.jpg
6. New light with existing pancake box and new mounting bracket. I've adjusted the 2 mounting screws from pic 4 to recess as far in as I can.
http://i684.photobucket.com/albums/v...00816-1958.jpg
As you can see it sticks out a good 3/4" from the wall. I don't know if I have any other option at this point than to cut a hole in the wall and mount a box inside the wall. Again, I'm pretty reluctant to do this as I have no experience doing this kind of thing but I'm willing to learn! Why is it that a seeminly simple job is never as easy as it should be :censored:
Thanks again guys for any input!
Lynch 08-22-2010 08:05 PM
Anyone else offer some ideas/help?
Proby 08-22-2010 08:16 PM
Last sentence of Post #2 :thumbsup:
frenchelectrican 08-23-2010 02:06 AM
I will suggest that you buy a old work juction box and that will really set it back nice and you will not have anymore issue with it or get a oldwork pancake box { little hard to find it } but best is old work steel box due you have BX cable there.
Before you sink in a box make sure you don't hit the stud if you do the pancake box will be the best item you can use.
Merci.
Marc
Lynch 08-24-2010 08:13 PM
Thanks for the idea french. I like the idea of using an old work box but am having a heck of a time finding a metal one that will work with BX cable. A round one would work best because of the mounting bracket for the light but I can't seem to find one anywhere! The plastic round old work boxes are readily available but that wouldn't work for BX cable as it needs the ground of a metal box, correct? Any idea where I can find a metal round old work box?
The closest thing I've found so far is this:
http://www.garvinindustries.com/Images/54171-DEOW.jpg
frenchelectrican 08-24-2010 08:27 PM
Here a link or two what the old work box with 1/2 inch KO so you can use the BX cable.
The first one only if you have no stud behind then you can use this one.
http://www.lowes.com/pd_74219-427-50..._?rpp=15$No=15
I have to find a photo for old work pancake box with support ears so it will be a little while and I know not very many places will have this kind of item.
Merci.
Marc
frenchelectrican 08-24-2010 08:29 PM
The photo you posted that will work just fine as well.
Merci.
Marc
oberkc 08-25-2010 06:25 AM
Perhaps another option to consider is to add a 3/4" thick decorative trim plate around the existing box, filling the gap between the fixture and wall.
