Problem With Extractor Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2008, 08:02 AM   #1
Problem with extractor fan
Hi, just wondering if anyone could help.
I live on the 3rd floor of a block of flats and I am having problems with my bathroom extractor fan. The owner of the flat below me has had a new fan fitted in her bathroom which is quite a powerful one and I am now getting air coming through my fan. My bathroom now gets slightly damp and small particles of dirt come through when she has her fan on. As we all share the same duct I was wondering if the was a fan I could have installed to solve this problem.
Thanks for any advice given
islandview is offline   Reply With Quote
Old 04-25-2008, 09:30 AM   #2
Registered User
Termite's Avatar
Your neighbor's new fan is strong enough to create back pressure in your portion of the vent it seems. The problem is the shared vent. That is a poor idea, because the static pressure in the vent will result in the air that's being moved exiting the vent via the path of least resistance (your fan).
Changing your fan probably won't do you any good unless you leave it running 24/7.
I would suggest finding a way to install your own vent (to outdoors) for your own fan and capping the old vent where it goes to your bathroom.
Old 04-25-2008, 11:22 AM   #3
Rewards Points: 160
Why not get the apartment owners or whomever is responsible for maintenance to correct the problem. If you share an air way with others, it would make sense to install one fan on the roof. This way everyone has the same amount of air movement, providng all the ductwork is exact. Then you can stink it up 24 -7. Also, knowone has to furnish there own fan.
I know nothing about HVAC. Just seems like the right thing to do.
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 05:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
