Old 07-21-2010, 01:59 AM   #1
Problem dishwasher
I got a used dishwasher off of craigslist well I get home and start installing it and it doesn't have a ground wire.. I have a cable coming from somewhere behind the wall that my old dishwasher was connected to. It has black, white and copper wire in it. But the new dishwasher only has black and white in the little box? What do I do?
usmcWifeyDIYer is offline   Reply With Quote
Old 07-21-2010, 07:07 AM   #2
Problem dishwasher
There is a green screw on the DW junction box, that is chassis ground, and where the bare conductor of your cable gets connected..
Old 07-21-2010, 07:51 AM   #3
Problem dishwasher
If you can't find the screw there should be a screw hole that will accept a green grounding screw. It may be that whoever owned this before you did not bother to connect the ground (which is dangerous as well as a code violation). If you can't find either the screw or the screw hole try looking for the owners manual online. It should tell you where it is. Do not install this without connecting the ground.
SleepyDog is offline   Reply With Quote
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 8 01-14-2011 01:42 PM
Dishwasher powder instead of salt - Doh! Bottletops General Discussion 0 03-03-2010 12:06 PM
the dishwasher won't drain anymore (due to broken glass?) diy'er on LI Appliances 7 12-14-2009 11:38 AM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 11:35 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
