Problem With Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 06:22 AM   #1
Problem with Circuit
Recently we have had a problem with a circuit breaker flipping in our house. I have isolated the problem to an outside potting shed that has a GFI receptacle which then runs to an outside light. I replaced the GFI and hooked up the light directly( no timer) and the light works fine and no problem with the circuit. The timer has been on this light with 5 years. As soon as I place the timer back on the circuit flips again. I purchased a new timer and same problem. Suggestions please. Thanks.
P.S. The timer is installed correctly.
oralpath is offline   Reply With Quote
Old 04-09-2011, 07:09 AM   #2
Rewards Points: 1,512
Does the breaker have a built in GFCI or arc fault circuit interrupter?
If you press on the receptaclewhere the timer plugs in with your thumb does that trip the breaker (wires inside the box moving and shorting)?
Old 04-09-2011, 07:25 AM   #3
Thanks for your response. The breaker is a a 20 amp standard breaker. I did see that the new GFI is a 15 amp, although the light is the only thing drawing power. Would the 15 amp GFI make a difference? Also, the breaker trips even before I push the timer back into the box.
Old 04-09-2011, 08:06 AM   #4
I=E/R
a7ecorsair's Avatar
Just to verify. It is the circuit breaker in the panel that is tripping and not the GFCI that is in the potting shed. Does this circuit serve any other load?
a7ecorsair is offline   Reply With Quote
Old 04-09-2011, 08:55 AM   #5
Correct. It is the breaker in the panel. If I hook up the wires directly( bypassing any switch or timer) the light works fine and does not trip the breaker. When I introduce the timer or switch it trips the breaker in the panel.
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 09:59 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Trane XE 80 Problem Espy HVAC 2 11-18-2008 05:31 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
