Problem After Installing Light Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 04:49 PM   #1
problem after installing light timer
I just installed a light timer - i had to put a jump on it to get a white wire, then everything worked .
Problem is the switch in the the room next it stopped working......
meoj123 is offline   Reply With Quote
Old 01-01-2013, 05:09 PM   #2
joed's Avatar
Rewards Points: 11,998
We need a lot more details of the wiring you changed.
Old 01-02-2013, 02:35 AM   #3
" Euro " electrician
frenchelectrican's Avatar
I am on the same page as Joed need more details and what colour the conductor it was on the oringal switch ( not the timer at the moment ) and is there a red conductor in there ?
Merci,
Marc
help wiring a timer in a 3 gang light box edadmartin Electrical 3 03-14-2010 09:05 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
Combine Motion Sensor and Timer for One Light fritzycat1 Electrical 9 11-22-2008 02:25 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
