Old 11-09-2010, 01:50 PM   #1
Problem
I recently installed a dimmer switch in my living room... The dimmer works fine however the dimmer itself, not the lightbulbs, is buzzing... More worrying however is that there are 2 other lights running off the same circuit breaker and now those other two don't work but the dimmer does... Anyone have any ideas?
Steve14 is offline   Reply With Quote
Old 11-09-2010, 02:10 PM   #2
Problem
What type of lights are you trying to dim? The other lights not working sounds like a bad splice.
lordlondis is offline   Reply With Quote
Old 11-09-2010, 02:15 PM   #3
Problem
They are just regular incandescent bulbs... And the other lights worked fine before I installed the dimmer
Old 11-09-2010, 02:37 PM   #4
Problem
Whats the wattage of the dimmer and is it sufficient for the lights? I would pull out the dimmer and check all your connections, it sounds like one of the wires feeding out to the other lights arent connected. Also make sure that the dimmer is properly grounded.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
